Wheel Options for 93 Cobra???
  • Thread starter Thread starter Adams91LX
  • Start date Start date May 31, 2009
First Prev 2 of 2
Admin Dude
Jan 4, 1985
43,277
21,448
234
Box behind Walmart
Feb 24, 2023
#21
  • Feb 24, 2023
  • #21
SVTCobrapilot said:
I’ve look there too. It also requires changing rotors and stuff. I never thought about calling them to see if they can be made with the 40.9mm offset. It’s a good idea thanks
If you're going to have to change things up no matter what, I really like the idea of those 9.5s in the back versus the OEM width. I'd do staggered in a heartbeat. I just really like the look TBH.
SVTCobrapilot
18
14
#22
  • Feb 24, 2023
  • #22
I want to keep it as OEM as possible but Staggered dose look good. Why you putting such things in my head. Lol
Admin Dude
Jan 4, 1985
43,277
21,448
234
Box behind Walmart
Feb 24, 2023
#23
  • Feb 24, 2023
  • #23
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,946
5,818
213
Feb 24, 2023
#24
  • Feb 24, 2023
  • #24
With your car being a true cobra I'd take all the original brake parts off. You could get away with a fox length 8.8 you can use the 94 to 98 rear calipers, brackets, and anti moan brackets. A machine shop can machine the newer rear rotors ( 5 lug ) to fit the 4 lug pattern. The center bore also needs to be machined. Fox hub is 63.4mm and the newer sn95 is 70.3mm. The sn95 brackets just need to be swapped side for side. Left brackets and calipers installed on right side and right on left. The orientation changes from the rear or front of the wheel well....ahead or behind the axle. This would give you the same offset as a stock fox mustang.
The only thing that makes the super coupe .75 wider are the axles to clear the brake brackets. I believe your 8.8 and a fox 8.8 have the same ends. Meaning the brake swap for a fox should bolt the same way to that rear. Just need fox length 4 lug axles, rotors drilled to fit, and sn95 brake parts. All rear brakes are the same from v6 or v8 from 94 to 98 except the cobra ( they had vented rear rotors and wider caliper brackets but same caiper )
You can also use NorthRacecar brackets https://www.northracecars.com/vintage_brakes.html
It's been a really long time since I've seen a turbo coupe rear brake set up.
SVTCobrapilot
18
14
#25
  • Feb 24, 2023
  • #25
That sounds like way more then I want to do. Lol. Maybe I can find a company to just custom make some 17x7.5 5.36” BS and 40.9mm offset lol
2000xp8
Aug 8, 2003
8,042
1,630
194
NJ
Feb 25, 2023
#26
  • Feb 25, 2023
  • #26
Is this just to preserve your original wheels?
93 cobra wheels can be found. There is a set on ebay right now for $2300 (in black).
Make an offer, ask him dismount the tires. Refurb as necessary.
Also a pair on facebook marketplace within an hour of me.
And that's just what i found in 30 seconds of searching.
If keeping your originals safe is your goal, not a different look, just pay up for another wheel or set.
Might even come up cheaper, since you won't have to mod anything.
Admin Dude
Jan 4, 1985
43,277
21,448
234
Box behind Walmart
Feb 25, 2023
#27
  • Feb 25, 2023
  • #27
--or--
Restomod the crap out of it and [still] get and have all the OEM pieces on-hand for the day that you never put that stuff back on again.
Reactions: AeroCoupe, Essn95 and General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
43,275
17,965
224
Massachusetts
Feb 25, 2023
#28
  • Feb 25, 2023
  • #28
Reactions: 90sickfox
First Prev 2 of 2
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
M
Need Wheel Measurement Help Please
  • MintyFresh
  • Nov 15, 2022
1965 - 1973 Classic Mustangs -General/Talk- Nov 16, 2022
manicmechanic007
Fox 18x9, 18x10 wheels
  • darryl paarman
  • Dec 15, 2019
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2019
darryl paarman
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
G
+40-45mm offset 17x9” wheel recommendations for 93 cobra
  • Gichris1983
  • Mar 27, 2020
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 28, 2020
KRUISR
