Wheel squeak / chirp
  • Thread starter Thread starter tone21g
  • Start date Start date Sep 5, 2011
tone21g
52
  • Sep 5, 2011
I have a wheel squeal/ chirp that is driving me crazy . Let me try to explain it.
When the car is rolling at almost any speed there is a squeak , a rolling "squeak squeak sqeuak" that can be heard. It sounds like its coming out of the rear, but I cant be 100%.
The one time it subsides a bit is when I brake. By rear pads are still good aswell as my disks.
Its driving me crazy and the one thing I can think of is maybee a barring back there?? I dont know - does any one have an experience like tis??????
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 5, 2011
  • Sep 5, 2011
I had that once, it was actually the spedometer cable. There is actually a physical cable that turns that runs from the transmission to the back of the speedometer. I just sprayed WD40 down the tube from the speedometer end.
Adams91LX
689
12
29
Plano, TX
Sep 5, 2011
  • Sep 5, 2011
yes... i have that experience.... every day i drive my car.
my pads/disc's are new... when i brake it goes away... man it's annoying.
stykthyn
5,232
2,652
223
gainesville
Sep 5, 2011
  • Sep 5, 2011
My jeep does that....
Adams91LX
689
12
29
Plano, TX
Sep 5, 2011
  • Sep 5, 2011
I feel like my problem... my car is over 30 years old.. if it didn't squeak I'd be worried?
MFE92
1,094
373
124
Phoenix
Sep 5, 2011
  • Sep 5, 2011
Lube the clip where each parking brake cable is bolted to the body ahead of each wheelwell. Pull the drums and put a dab of grease between each shoe and where it rubs against the backing plate.
tone21g
52
  • Sep 6, 2011
My car has rear disks, and the the parking brake isnt connected. . .
Thought - IF my rear end is low on fluid- would it inturn effect my wheel bearing??? Or is it not lubricated from there????
Cobra912
1,777
11
39
Wish I was anywhere but here
Sep 6, 2011
  • Sep 6, 2011
muffler bearing, damn things go on me all the time
MFE92
1,094
373
124
Phoenix
Sep 6, 2011
  • Sep 6, 2011
These are things that are good to disclose in the first place. Look to see if your pads are worn down and the "squealer" is contacting the rotor. Also look to see if the rotor is contacting the caliper bracket.
And since you haven't said if the squeak is at wheel speed or faster than wheel speed, see if your parking brake cable assembly is rubbing on the driveshaft.
ID89GT
1,659
18
49
Spokane Valley, WA
Sep 7, 2011
#10
  • Sep 7, 2011
  • #10
Control arm bushings maybe?
E
eighty8
34
Salt Lake City, UT
Sep 7, 2011
#11
  • Sep 7, 2011
  • #11
Mine does the same thing after I finish washing her. I just figured the rear disk brakes are squeaking for a bit until it dries. My E-brake doesn't have a working cable hooked up to it either.
N8Dogg98
3,872
238
184
MN
Sep 7, 2011
#12
  • Sep 7, 2011
  • #12
Mine does the same thing. I realize it isn't a fox, but I have the same noise and it sounds like its coming from the rear. It's especially bad if I'm driving close to a curb or a cement barrier (reflects the sound into the cabin). I hope someone has an answer.
It almost sounds like a squeaky bicycle wheel where the rim is slightly bent and it touches the brake pad on each revolution. I have relatively new brakes that still have plenty of pad life left. I suppose it could be my MM control arms squeaking, it seems to do it worse when the road is bumpy.
tone21g
52
#13
  • Sep 7, 2011
  • #13
I said that the noise is out of the rear, and that the disks and pads are new -referring to the rear
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Sep 7, 2011
#14
  • Sep 7, 2011
  • #14
My 93 had a squeak as well, sprayed all the bushings down with WD40. Mine went away for a little bit than came back. Next I used process of elimination by doing one at a time, until I found the one .
TenorPlayinGuy
1,208
Canyon Country, Ca
Sep 7, 2011
#15
  • Sep 7, 2011
  • #15
My wheel bearings did the same thing. Sometimes it sounds like it is in the rear, but in many cases its actually the fronts
Just my .02
tone21g
52
#16
  • Sep 11, 2011
  • #16
So I hate it when people make these types of threads and never give the results to what happend. With that said - UPDATE:
I enlisted my lady to help me with driving the car around and listen for exactly where the sound was coming out of - We concluded that the noise was in the right rear. So I took that tire off and started poking around. I noticed that the bolt for the bottom of the shock mount to the axel was loose. I tightend it, put the wheel back on - test drove it, and the noise went away
I dont know why the loose bolt translated into making that noise?? But it did . . .weird
Reactions: 562pitt
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
