  • 1994 - 1995 Specific Tech
Wheel Stud Replacement Procedure??
  • Thread starter Thread starter mojowrkn
  • Start date Start date Oct 21, 2005
M
mojowrkn
30
Charlotte, NC Area
Oct 21, 2005
  • Oct 21, 2005
I need to replace a cross threaded wheel stud and was wondering what the procedure is. Will I need to remove the entire hub or can it be manuvered out with the hub in place? Thanks in advance for your help.
FORCED2DV8
458
Grand Rapids MI
Oct 21, 2005
  • Oct 21, 2005
I have done without removing the hub, pound the old one out, you may have to rotate the hub to acheive maximum clearance, then slide the new one in and i use a open end lug nut, aka acorn nut with some washers and tighten it all the way down to sinch the new stud into place, you have to giude it in as you do it. loosen the nut and your all set.
illwood
636
Worcester, MA
Oct 21, 2005
  • Oct 21, 2005
It will work, but I prefer to take the hub off and use a hydraulic press because I don't like impact loading the bearings.
HISSIN50
34
129
Oct 21, 2005
  • Oct 21, 2005
Wise man here.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Oct 21, 2005
  • Oct 21, 2005
Yes, bearings are good....
HISSIN50
34
129
Oct 21, 2005
  • Oct 21, 2005
Wow, Scott really likes bearings.
I would note that swapping one stud is no biggie in all probability. I would not want to swap all the studs or anything like that w/o having it on the bench though.
bobbyo
  • Oct 22, 2005
I've found that an impact chiesel with a blunt point bit will punch them out cleanly. If you have ABS brakes, you may have to cut the stud prior to extraction in order to clear the pick-up gear. To insert a new stud, you may have to grind a flat spot on the gear to get the stud in postion. If you don't have ABS, you're good to go with the procedures outlined in other threads. Good Luck!
M
mojowrkn
30
Charlotte, NC Area
Oct 23, 2005
  • Oct 23, 2005
Well I removed that bad stud with no problems at all and I didn't have to remove the caliper. I just rotated the assembly until the stud lined up with an open space in the dust shield and tapped it out. I put the new one in through the same space and used several washers and a lug nut to pull it snug. Thanks again for everyone's input. Hopefully this thread will help someone in the future!
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
J
Replace/Repair under dash harness on 67 coupe
  • jv53
  • Dec 12, 2025
Classic Mustang Specific Tech Dec 12, 2025
Mcmahst
