wheel studs
  • Thread starter Thread starter jaackal
  • Start date Start date Jul 27, 2005
J
jaackal
402
NJ
Jul 27, 2005
  • Jul 27, 2005
how do i put new wheel studs in? do i just bang them into the axle with a hammer? i already have new axles and they are out
J
jaackal
402
NJ
Jul 27, 2005
  • Jul 27, 2005
ttt
Fishhawk
281
Michigan City, Indiana
Jul 27, 2005
  • Jul 27, 2005
No you don't bang them in. If you have an impact wrench then you can pull them through with that. Just use a little WD40 on the knerl and put a couple of washer on the other side. (brake side) Finger tighten down a lug nut on the washers making sure the stud is straight, (Nut flat side down) then carefully tighten the nut down with the impact wrench. It should pull the stud through. If the axles and studs are hardened then you will probably need them pressed in.
stanggt
575
Silverdale, WA
Jul 27, 2005
  • Jul 27, 2005
You need to get them pressed in either by a good machine shop or you can do them yourself...if you have a hyd press and the knowledge. Either way it does not cost much and will be installed straight. If you "bang" them in you might not get them straight or damage the knurl/axle.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 28, 2005
  • Jul 28, 2005
It depends on the axle and the studs you have. My Strange axles are screw-in studs, factory would be press-in.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Axleback installation
  • Bob Foos
  • Jun 13, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jun 15, 2026
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
D
Drivetrain car still rolling while in gear and off
  • dqureshi06
  • Jan 24, 2026
Fox 5.0 Mustang Tech Jan 24, 2026
General karthief
