wheel studs??
  • Thread starter Thread starter jimsstang91
  • Start date Start date Apr 12, 2006
jimsstang91
101
  • Apr 12, 2006
can someone tell me where i can get wheel studs 1/2 inch longer than stock? without spending alot of money. maybe from a diffrent type of car.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 12, 2006
  • Apr 12, 2006
not sure about that but i guess you are saying you don't want to go and buy moroso or arp wheel studs. i bought arp ones.
GearHd6
459
Ashford, CT
Aug 16, 2006
  • Aug 16, 2006
What part # studs did you get? I need studs about a 1/2" longer also. Im just not sure about the knurl size. I can mic over the actual knurl on the studs I popped out and I get .584 and I measure the preknurled part of the stud and I get .565 so im not real sure what dimension is the important one. I know they're 1/2"-20 studs but the knurl is killing me. Are the studs the same front to back because I havent popped off the drums yet?
1991vert
1,103
Ludlow, MA
Aug 16, 2006
  • Aug 16, 2006
you can't take them from another car without taking the whole axle. the knurls on the studs will already be crushed. so if you try to pop them out, they're useless.
moser has some that are longer
bill302
2,131
alabama,gadsden
Aug 16, 2006
  • Aug 16, 2006
heres some moroso rear studs...1 inch longer if your intereasted
http://cgi.ebay.com/ebaymotors/Moro...ryZ43957QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
GearHd6
459
Ashford, CT
Aug 16, 2006
  • Aug 16, 2006
I found the correct part #, no drilling required. Just took a little searching. Thanks though.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 16, 2006
  • Aug 16, 2006
i need studs also, what is the knurl that we need?
1991vert
1,103
Ludlow, MA
Aug 17, 2006
  • Aug 17, 2006
Thread Size: 1/2-20 RH in.
Knurl Diameter: 0.615 in.
Underhead Length (in): 1.500 in . (stock length) they also have 3.000 in.
mob
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Aug 17, 2006
  • Aug 17, 2006
k thanks man, the underhead length is just how long it is right?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Aug 17, 2006
#10
  • Aug 17, 2006
  • #10
No... The length is how WIDE it is.........
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 17, 2006
#11
  • Aug 17, 2006
  • #11
I used ARP studs and cut them down to a length I needed with a grinder. If you do that be sure not to heat them up too much and also thread a nut on BEFORE you cut them. I had a friend blow compressed air on it while I hit it with the grinder. Finally, file the end and then unthread the nut for a great functioning stud.
1991vert
1,103
Ludlow, MA
Aug 17, 2006
#12
  • Aug 17, 2006
  • #12
why not just buy the correct length to begin with?
rd
3,316
63
109
Ocean Springs MS
Aug 17, 2006
#13
  • Aug 17, 2006
  • #13
Note to all in this thread.
This is harder to do than you would expect. I have yet to see a catalog that lists all the characteristics of the stud, length, thread, knurl diameter, etc, AND cross references Fox Mustangs. Jegs and Summit don't do it.
I too, have two packages of the wrong ones, after buying them on "good advice." Still working on this.
GearHd6
459
Ashford, CT
Aug 17, 2006
#14
  • Aug 17, 2006
  • #14
Ok heres the deal. The proper studs that require no drilling are these. Moroso part # 46185 Summit has them listed as part # MOR-46185. The knurl is .594" on those studs.
GearHd6
459
Ashford, CT
Aug 20, 2006
#15
  • Aug 20, 2006
  • #15
Ok, UPDATE! What I posted above stands true for the front studs but for the rear you'll need different studs. The correct studs for the rear are Moroso part #46180 or Summits part # is MOR-46180. Those are .615 diameter knurl and short length knurl so they won't hit the lug nuts when tightened.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
