- Dec 4, 2005
- 101
- 0
- 0
can someone tell me where i can get wheel studs 1/2 inch longer than stock? without spending alot of money. maybe from a diffrent type of car.
86bluecobra said:not sure about that but i guess you are saying you don't want to go and buy moroso or arp wheel studs. i bought arp ones.
mob said:i need studs also, what is the knurl that we need?
1991vert said:Thread Size: 1/2-20 RH in.
Knurl Diameter: 0.615 in.
Underhead Length (in): 1.500 in . (stock length) they also have 3.000 in.
No... The length is how WIDE it is.........mob said:k thanks man, the underhead length is just how long it is right?
tunedin302 said:I used ARP studs and cut them down to a length I needed with a grinder. If you do that be sure not to heat them up too much and also thread a nut on BEFORE you cut them. I had a friend blow compressed air on it while I hit it with the grinder. Finally, file the end and then unthread the nut for a great functioning stud.
