wheel studs
myslo50
247
ohio
this is for my 88 gt.............
i bought moser 28 pline 5 lug axles for my car, question is for the wheel studs, do i use studs for a 88 gt and order 5 per side, or do i order studs for a 95 gt since
the rims im using are the 94-95 17x8 tri bar?
The Ford lugs are the same for Fox and SN95 rear axles, I just looked into them the other day. If your car is just a driver, then go with those...you will be fine. But if you plan on putting drag radials, then you might as well get some stronger studs. If you are going to run it at the track on slicks then you NEED to get some longer, stronger studs.
I personally just opted for the 2.5 inch lugs from Steeda, they are more expensive than the 3" ones...but Steeda says they will fit with center caps. I am doing my 5-lug conversion and am going with stock 97 GT wheels, so I wanted strong studs that will hold up on slicks with hard launches, will pass tech, and will fit with stock center caps.
