Wheel Hop?
Ozsum67 said:
Clutch slipping........could be. Nothing wrong with air shocks if you want a firmer ride, an adjustable ride, and adjustable ride height. 70s or not.
I agree with your usage of air shocks BUT:
1. If you need air shocks because when two people sit in the back of the car
then there is another problem you need to solve.
2. If you need air shocks because you tow with your Mustang then there is
another problem, you bought the wrong car.
3. If you are looking to maximize the performance of even a stock mustang, I believe the first thing to do is get the suspension stable.
- New aftermarket leaf springs (Originals sag in a month)
Lowers by 1/2 to 1 inch
- Lower front A-arms ~ 1-inch (Shelby Mod)
- Cut front springs to preference (flat, slight rake on ride height)
- Get sub Frame connectors
- Move the battery to the back and remove as much weight of the frontend
as you can;
Stock drums to Wilwood disks 30lbs.
Aluminum Heads/Intake/pulleys 50lbs.
Headers 20lbs.
Fiberglass hood 20lbs.
Alu Pulleys 5lbs..
*Electric Fuel pump in rear 5lbs.
*Battery in trunk 25lbs.
Moving the battery/ pump is a double word score i.e -30lbs. off the front and +30lbs in the trunk area!
Improving the balance on the car by ~ 5%
Improving overall weight by ~ 7%
is huge, not to mention the drive-ability. A lowered classic stang handles much better and is more condusive to the way we drive today. And now you can apply much more of that HP to the road instead of into sub-frame torque, wheel hop, etc.
-Q
