When do you shift? Race/Eco
500rpm past your peak HP is a good starting point and is what you should do at the track. Once your 60ft is dialed in and consistant, then play with the RPM to see what the car traps. Go up/down and make a lot of passes. I always like to shift right before 6k in a 2v with PI gear.
2-2.5k when I'm driving normally. 3-3.5k when I'm having fun. I'm a chicken I guess.:shrug:
:ban:
Just kidding, but you're not even hitting the torque peak. What do you think is gonna happen when you wrap it around? It's not like it's not made to be revved. The sound when it passes 5K in a tunnel is worth the price of admission, IMHO. Not doing it is a waste of money.
:ban:
Thanks for the advice. I've never had a "sports" car before and I can't get over the fact that I'm not going to hurt it by taking it that high in the rpms. I'm still learning.;)
They are reliable engines, The first time i took my car to the track on m/t's, i was having a hard time getting them to melt long enough (stock 3.27's) :notnice:
So lets just say one of my burnouts found the limiter a few times.... The mickeys were hot at least :D
You and me both!:rlaugh: Daily driving I shift at about 3000 RPMS. When I'm "driving with spirit" its around 5800 RPMS
I'm still getting used to the car. It seems (almost) like it doesn't have the power that it should??
Again, I'm new to it
After driving your car for a while, you can shift based on feel and never really look at the tach. In heavy traffic, I find myself short shifting, to keep the engine between 1000 and 1500. I don't need the power, so I shift earlier and keep the revs down. That makes it easier to get along with in traffic and saves gas. I sometimes skip gears too, and do a 1-3-5 shift pattern, or start in 2nd and go 2-4-5, especially downhill when you don't need much throttle.
In normal driving, I like to keep a heavier load on the engine at lower revs, so I'll shift before 2000. This gives better gas mileage and wear. It is a V8 and still has plenty of torque below 2000rpm, don't be afraid to dip into the gas below 2000rpm, you aren't going to hurt anything and you'll find better gas mileage. I've been getting 22-23mpg in mixed driving with fun on every highway on-ramp. :D
As for racing, a stock PI would probably be fastest shifting around 5800. You can bump it to 6000 after doing a few modifications. My NPI did best shifting at 5000 stock, but I think 5200 would be better now with a few light mods.
