When I step On it it Chokes
Xterminator03
157
NEW YORK
I have an 89 Gt with a carb, BIG cam, heads, and pulleys.
Every time I step on the Gas Hard the car chokes. It feels like it stop accelerationg for a second than it picks up. on couple of occations when just reving engine the carb flooded. With this Problem I can't get no instant power form my Pony. What could the Prblem be. One frined suggested it was the mettring jets. but I don't know I also cleaned the Carb but still same issue. Please Help. :bang: undefined
how big is the carb?
what size power valve are you running?
how much vaccuum are you pulling?
whats your definition a "big cam"?
give us some specs and maybe we can help out.
later
Carb Holley 750
Camzilla Z303, Advertised Duration 290/290, Lift .552/.552,
Plus 1.7 Roller Rockers
how much vaccuum are you Pulling?" - -Dont Know
Eldelbrock Air Gap RPM
5 Spd King Cobra Clutch
I Forgot to Add World Roush 200 Heads They're Polished
First off, you combo is too large for your engine. 200 cc runners with a 302 is too much, and so is that cam. Lastly, your intake is too small to match with those heads. What the cc size for those chambers. As for it flooding, it could be the float adjustment or your needle and seats need to be changed. You should just get the car dynoed and it will fix your problems. You have what is called an off -idle bog which can be caused by being too lean or too rich, but it sounds like too much gas caused from the float adjustment. What do you mean its flooding. Like the car wont start, or you just see gas dumping into the intake from the bowl vents? We need more info. Adjust your floats correctly, and step down a few jets and let us know.
Is this a problem that occured after your combo was together and running well? Or did you bolt everything together and these are the problems you're having now? If you just put it together than I would guess you're carb is simply out of tune rather than having a mechanical problem. 750cfm is on the large side for your combo IMO. As others have mentioned, make sure your float levels are adjusted correctly. Also, make sure the rest of your engine is in tune, the timing and advance curve need to be set properly before you try and trouble shoot the carb.
If you haven't already, I recommend you buy a Holley carb book. It will give you specific instructions on how to change the float levels and adjust the accelerator pump.
A few more questions: Did you buy the carb new? What size jets are you running? What power valve are you using? How large is the accelerator pump? -I think some 750 Holley's could be ordered with a 50cc accelerator pump, which would be way too large for a mildly built 302.
Finally, one of other posters asked an excellent question: How much vaccum is your engine pulling? If your cam is that big, and you're not pulling very much vaccum...and your carb has a power valve set for a "stock engine" your main jets will open far too early, causing a bog.
Edit: How much fuel pressure are you running?
sorry for all the random questions, but this problem should be easily solved with a bit more information.
The Heads Have a 64 cc in the Chambers, The Carb does have a 50cc Acelerator pump,
When first installed the set up was working fine but after about 2 weeks and 2 races it started happening. (This same exact setup was in my friends car; same parts with addition of MSD and exhaust and was running perfectly fine)
When I say it floods i mean it will not start. ( and the only way it does start after this is if I open the hood floor it and turn the key) This letting me understanf that I need more air.
Its definetely running too rich if your always flooding it. I still think your parts are too much for a stock 302. That cam and those heads are designed for high rpms which must be killing your bottom end, and your lowend power and torque. Also, a 64cc chamber is going to give you even less compression than stock which is already too low for a cam that size. You cant have any intake runner air velocity with sub 9 to 1 compression ratio and 200 cc intake runners. Screw the idle mixture screws in all the way, then back them out 2 turns, and step down a few jets. Check your throttle response. You want it to be crisp, and your idle shouldnt hang after the throttle has returned. Your exhaust shouldnt smell like a lawnmower either. Keep tuning till your rid of the off-idle bog, the idle returns directly after let off, it starts easily, and the exhaust smells decent. Also, what is your timing at?
On top of each bowl there is a large screw head and lock nut. And on the side of the bowl there is a screw. Remove the side one so you can see into the bowl. By using the top screws, adjust them until the fuel level in the bowl is just touching the bottom of the hole you made by removing the screw on the side. You'll make this adjustment as the car is running and warmed up. Basically by screwing up or down that top screw, you are adjusting the height at which the bowl float shuts off the needle and seat to stop gas from entering the bowl. Too low, and you run out of gas as you are racing. Too high and you can run too rich, or gas can slosh out of the vent and flood the carb.
