When to replace timing chain?
  • Thread starter Thread starter 87lc2
  • Start date Start date Nov 10, 2005
87lc2
214
Nov 10, 2005
  • Nov 10, 2005
As far as i know, my 93k motor has never been opened. Just wondering when the recommended time to change the chain is....
87'GTstang
1,025
  • Nov 10, 2005
The 5.0 HO used a double-roller timing chain. A lot can get a couple hundred thousand miles out of them with no problems. If you start having inaccurate ignition timing and are having problems with power (when compression and leakdown testing test fine), the only way to check is to get at it. Most will say using a dial indicator, .50" of deflection is about the service limit if you want the nitty-gritty.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Nov 10, 2005
  • Nov 10, 2005
I agree, the engine will often wear out before the timing chain is an issue. At the same time, if you ever do cam change or have the timing cover off, its not a bad idea to replace it anyway.
87lc2
214
Nov 10, 2005
  • Nov 10, 2005
thankls guys, i didnt know it was a double roller design, im my buicks its not and they have to be replaced every 100k or so....thanks
Autobodypro_1
76
Florida
Nov 10, 2005
  • Nov 10, 2005
Timing chain
I wouldn't worry about it unless you change cams or the car runs ragged due to chain stretch(not likely). The double roller chain has no plastic parts like your Buick so it will last as long as the motor itself.
87lc2
214
Nov 10, 2005
  • Nov 10, 2005
thats what i needed to know, the buicks have plastic gears from GM and can completely wear down.....guess the Ford guys were smarter.....
8950HO
658
  • Nov 10, 2005
If you put a socket on the crankshaft pulley/damper bolt and turn the crank a little back and forth you can feel the timing chain play by hand and it kind of gives you a ballpark feel of how tight/sloppy it is.
I forget now,but I recall from the past that if it was more than "X" degrees play on the timing marks,a new chain was in order.
But like someone stated,the 5.0L roller chains last a long time.I checked the play in mine at just over 100,000 miles moving the crank by hand each way and it felt extremely tight,with just very slight play when turning right and left on the crank.
87lc2
214
Nov 11, 2005
  • Nov 11, 2005
there is no play at the crank at all, i replaced the balancer last night and was just wondering about the chain since i was pretty much halfway there....guess ill leve it alone for now thanks
O
Timing guide
  • oilleak1000
  • Oct 10, 2026
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 10, 2026
oilleak1000
O
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
For Sale 2007 MUSTANG CONVERTIBLE/137,797 MI/ 20,000+MI NEW ENGINE/BRAND NEW TIRES/$4500 OBO/WAUKEGAN, IL
  • Savage21!
  • Sep 10, 2026
  • S197 Mustangs For Sale (2005-14)
S197 Mustangs For Sale (2005-14) Sep 10, 2026
Savage21!
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
