Where are these?
zZsKyZz
503
Where can I find [on the car]:
-TCC Solenoid
and
-Shift Control Solenoid
and
-Pressure Control Solenoid
My car won't shift from 2nd into 3rd and the check engine light is coming on leading me to guess that it's a sensor not allowing it to shift. Any ideas? Pictures would make me :D
i know the tcc and pressure solenoid are in the valve body. the shift control soleniod may be in the same place too. if you look at the tranny on the passenger side where the big white connector is, i believe the solenoids are in that area. i had to rebuild my aode that was in my 94 tbird.
How hard is it to get to the valve body? Do I need to completely drop and remove the transmission to get to it?
Problem:
My car won't shift into 3rd, I read that it could be a sensor. Due to my Check Engine Light being on, I'm starting to believe it is... I just got a code reader and I'm about to go pull the codes as soon as I learn how to use the damn thing... I'll let you guys know.
