Where can I buy an upper and lower girdle?
Daggar said:
and a pretty worthless install to boot. It doesn't keep the block from twisting so it won't keep the lifter valley from splitting either.
Andy may be old as dirt but he sure knows his shiit :nice: (at least in this thread he does :p)
Personally, I DO think the lower girdles are worth having. A little extra beefing up of the 2 bolts mains certainly couldn't hurt. Although the lower girdle doesn't "share the load between all the mains" like many advertisers would tell you. It does help reduce at least some of the load on those 2 lonely bolts per cylinder. It will also spread out some of the vibration harmonics at higher RPMS. The best part, is that if your block ever DOES split, then it stand a good chance of holding the pieces together so that your internals can be reused.
