Where can I get a rebuild kit for a 2.3L Turbo?
parts store.
I just got all my stuff from advance this past weekend. Just about every gasket for it was like $5 or less. Only one that was $$$ was the head gasket because I didn't go for the stock replacement felpro one for $13, I popped for the $45 #1035 felpro head gasket since it's got stronger combustion rings on it to help with higher boost which this engine will definitely see :hail2:
also, for your pcv valve that you'll most certainly want to replace go get the FORD motorcraft one. I recently learned that it is "special" to the turbo motors.
motorcraft# EV-127-A at a dealership parts counter. Also, make sure you get a rubber valve cover gasket and that it has the little metal rings around the bolt holes (they are torque-to-yield) so that you can't overtighten them and break the aluminum valve cover...and yes, it's reusable.
thanks thats what i needed to know. I was lookin on that Northern Auto Parts and found a 2.3L Turbo master kit that includes:
Federal Mogul Moly Rings
Federal Mogul offset recessed head Pistons
Federal Mogul Rod Brgs
Federal Mogul Main Brgs
Federal Mogul Cam Brgs
Melling Oil Pump
Federal Mogul Camshaft
Federal Mogul Lifters
Melling Timing Components
Pioneer Frost Plugs
Victor Gaskets
for $334.04
Is this a good kit or should i just buy things piece by piece?
Melling Oil Pump
Pioneer Frost Plugs
Victor Gaskets
for $334.04
You don't want that kit anyway, the pistons are hypereutectics which don't hold up in a turbo engine.
