HP would be dependent on what combo you go with (cam, heads, etc.). I had them do just shy of a shortblock for my setup. I run one of the mildest cams for a stroker motor, use out of the box Trick Flow TW heads, out of the box carb (tuning, but no mods), and I put down 338.9 rwhp and 335.5 rwtq. There is alot left in my engine but I don't have the tires to harness it, yet. My 245/45-17 tires are no match for my setup. Before you get too concerned with engine "numbers" make sure you address the peripheral systems of the car to handle it. Chassis, driveline, suspension, brakes, etc.. should all be considered.
