Whats a good place with quick delivery and good prices. also where can i get a mass air meter that will bolt up to the stock air box. the cai i have requires a flanged MAF so i need one that would bolt up to the stock airbox.
75 mm accufab, i need to get a MAF that has the stock flange setup, does anyone know where i can get one. the c&l MAF's have no flange and are supposed to be used with their k&n set up. i already wasted my money on a steeda CAI so i'm stuck with it.
If you are going to use a C&L plenum, then go for the 75mm because the inside diameter of the opening on the plenum is 75mm. If you are going with an Accufab plenum, then get a 70mm because its ID is only 70mm and a 75mm TB will be pointless.
