where do i find svt focus pump
i have one in my garage brand new in package. i wouldn't recommend using one because of the flow charts but it's up to you. $75.00 if you want it. i would recommend walbro pump gss342.
Here is a little info on using different pumps in late model stangs-
The newer stangs (I believe starting in 99') have a returnless fuel system. They use a module that pulses the fuel pump on and off. The pump does not run all the time.
The fuel rail pressure sensor sends a signal to the module when the rail pressure drops below a specif amount.
Make sure when getting a pump, To get the right one. If not the pump will burn out. The pumps are designed differently for return and returnless systems.
Afastgts95- I see by your mods that you have a 5.0.
Do not use the focus pump. Get yourself a high pressure 255lph designed for a return fuel system i.e. 86-98 models.
I hope this may help you.
The walbro I had failed in 3 months its not designed for the returnless style fuel systems that is in the 99 and up mustangs. Walbro is a bigger pump but not a better one. The svt focus pump is good to 400 rwhp. Now the lincoln aviator pump I have is good to aleast 500 hp at 281lph and has been designed for fords new returnless fuel system. If his car is a 98 or older then the walbro would be a better choice.
I switched a walboro 255 for a focus SVT last weekend, just in case it decided to die. the car only had a few thousand miles since the walboro, but i figured better safe than sorry. If the focus SVT pump is good enough for Modular Powerhouse to sell with their Mongoose Kits it's good enough for a basic bolton bullitt! Plus paid about $32 shipped off ebay, brand new.
