I looked at some diagrams and can't figure out which ground is actually for the radio.
I am trying to see if I am having a ground issue with the dash. I am having the standard "temp gauge moves with lights turning on" issue, but it ONLY happens with the lights and no other electrical load. Right now for instance, when I turn on my blinker, the temp gauge jumps slightly each time the blinker flashes. Right now one of my cluster bulbs is out for the right blinker, and when I turn on the blinker the temp gauge does not move (outside blinkers working fine). So I know it is only effected when the lights in the cluster are lit.
Also, I am having issues with radio reception. Two different radios have horrible reception, including a HD turner radio (HD turner built in). I pretty much have to drive into the lobby of the radio station in order to get a clear signal. I ruled out antenna. I used a new antenna wire, new antenna base, and new antenna. Didn't change anything. First I connected it and just held the antenna outside the car, then I installed it properly, no difference. Yet when I plug either of these radios in another vehicle, the reception if great. So it is something with my car, and it is NOT the antenna, cable, or base.
This all leads me to a ground issue. Right now I have a 2 gauge wire with soldered copper lugs as grounds. I replaced the ground strap from the head to the fire wall with one. I also have the same thing going from the block to the sway bar bracket on the frame (right side of motor), and another going from the block to the frame rail on the left side of the motor. I double checked all the visible grounds in the engine bay, the one on the header panel, and the ones near the starter solenoid. I cleaned all the metal for those grounds and reconnected them all. So I am thinking I am missing a ground or two.
Basically I just need to know which body ground is for the cluster and which one is for the radio...and if they are the same.
Thank you.
Thank you.
