Hi guys, I did a Ford HD clutch install 1500 miles ago. The steel Ford TOB started that annoying squeak when the clutch pedal isn't pressed in. Not even 1000mi had it started. Thats the same p/n TOB that came off my car before and that one had 100k on it and never squeaked at all so I figured it was a good bearing to go with. I might not of lubed it up enough when I put it on. Anyway, I got a really fine grease gun fitting and an extended hose to get up in there. But before I do, where exactly should I lube? Is it the bearing retainer shaft I want to put some on? And then disengage/engage the clutch a few times to lube the retainer up? Also I used lithium based grease before, it says it can withstand really high temps and stuff. Should I stick with that or find a different grease. I don't think it's the white you guys were talking about.
