Where is the cruise control module located on a Fox?
ponycar17 said:
As the topic indicates, where is the cruise control module located on a Fox? I know that the servo is located in passenger side fender, but where is the control module located? Thanks a lot in advance! :nice:
If you mean the speed control amplifier...............
rd said:
Under the dash at the firewall on the drivers side, to the left of the steering column, and above the kickpanel. It is a rectangular black plastic box with wires going to it.
The ones that I've pulled out are a rectangular white plastic box with two plugs - one from the dash harness containing the power, ground, steering wheel control inputs, and VSS input, and the going to the servo.
-P51C
