I am in the middle of a new water pump install on my '87 GT. In the process of removing the old one, I broke the two upper water pump bolts that go through the timing cover. I got a little lucky there, and it looks like I can just drill them out, retap the threads and put a couple new bolts in... if nothing else, I'll just stick two bolts through and put a couple nuts on the back side to hold the pump on.
Anyways though, my question is where can I find a water pump bolt kit? I called the local Ford dealership in this town and talked to the parts department and they said they sell each bolt individually and that they run anywhere from $5.50 to like $9.50 a bolt. That seemed a little up there in price. The newest Jeg's magazine I have has a listing for ARP timing cover and water pump bolt kits. They have 3 different ones and I am not sure which one to get.
They have cast iron, aluminum and stainless bolt kits for SB - Fords. So I am going to assume that they will work with any SB Ford motor.
Anyways, which should I go with?
Some of the part #'s are:
070-154-1502 for cast iron
070-154-1504 for aluminum
070-454-1504 for stainless
That is with Jegs.
Thanks!
That is with Jegs.
Thanks!
), I'll see if I have the link saved at home. When you get into graded bolts over 6" they start to get expensive.
