Where to set timing from?
mooktank
237
look at the pic. I set my timing to 10 BTDC according to mark A. so is that right? truck still runs kinda bad when warmed up.
cant tell a damn thing from the picture but basically what I do is put a grease pencil mark on the 14deg mark (or whatever you want to set it at) and then spin the distributor until the piinter is pointing at my mark. Make sure to pull the spout connector when you set the timing or it will end up way retarded.
Are you using a Advancing Timing light with the dial... cuz if those aren't set correct then you can throw your timing off. But if you have a standard one then you just mark 10* or whatever you want it at and then line it up with the pointer by turning the distributor.
