Ive had my car dyno tuned at blood enterprize. They did a pretty decent job but expensive and really not the results i was expecting. I live in Federal Way but i can trailor the car wherever. Thanks
Blood has a Mustang Dyno. Their Dyno typically reads low. You could go some were that has a Dynojet and do some power pulls just for a number.gospeedgo said:What dont you like? Is the A/F off? Pretty much all your doing on a dyno is making sure its safe and getting a number to bench race with, The drivability stuff is done on the street. If you just want better numbers, go to a place that has a Mustang dyno and have them fudge your correction. Numbers wont do a damn thing for you, the track will tell the whole story.
breakemlose said:I've been fooling around a lot with methanol lately.
NA motors 12.5:1 ish
Forced induction 11.3:1
Methanol + forced 10.75:1
Methanol I've noticed from knock sensor values prefers a rich invironment.
Also you don't have to overly retard timing out when running the methanol either. Personally i dont' change the timing at all if any i add timing
what shops fudge numbers and how do they do that by changing the load on the dyno or some other way?gospeedgo said:that was essentially my point, although they would not likely fudge their numbers like some less reputable shops may.![]()
numbers are just numbers....whats it run in the 1/4?
so what non-reputable shops should i not take my car to to get a bad tune the reason i ask is that im almost ready to get the car tuned and dont know where to take it yet any input would be good thanksgospeedgo said:As I am to understand, Mustang dyno's require a lot of input regarding car weight and such that allow a lot of variables. Chances are, if you took your car to different places, they likely would use different numbers and in turn your HP numbers would be greatly different. It would be very easy to manipulate a HP increase just by changing, say the cars weight.
lamrith said:Wow 1400 for a dyno tune and they were not "willing to get into it?!!??" I would have had serious issues with that. I have also heard many nightmares about that place. I know I will NEVER go there or recommend anyone go there.. They Charged a buddy $600 to clean up some wiring as it was "not safe to nhra standards" for them to run it on thier dyno.. needless to say they didn't get paid for that BS as they had his car a month and never even tuned it...
lamrith said:I know I will NEVER go there or recommend anyone go there.. They Charged a buddy $600 to clean up some wiring as it was "not safe to nhra standards" for them to run it on thier dyno.
