so anytime i romp on the car, something goes wrong
anyhow, on my way home from the local cruise night, i gave the car a little gas (and by a little, i mean pealing all of 1st and 2nd).
stopped by a gas station to fill up for work today. as i'm getting out of the car, i smell coolant. i look underneath, and there's a puddle of coolant--as if it just dripped out at once, and didn't leak out anymore afterwards.
i pump gas and take off from the store, and as i'm heading out, my temp needle quickly jumps to the "RM", but then gradually (but quickly, still) makes its way down to the N.
i get home and can hear a little hisssss coming from somewhere, only i couldn't see since it was dark.
today:
don't take the car to school--hitch a ride w/ my fiance.
get home, go to the bank in my car (4 blocks away) and it starts to overheat once i get there. i turn it off, make a deposit, then as i'm driving out, the temp kinda fumbles around the middle, goes up a bit, then goes down a bit, then stays up, and i barely make it home (all 4 blocks away, hehehehe).
i'm pissed off, by that point. something's always going wrong, whether i romp on it a little, or upgrade (which ends up breaking something else that i need to fix), so i'm sure most of you guys can understand the frustration.
anyhow, i go out after a couple hours of cooling off and start trying to find what's wrong. w/ the car running and the heater on (after refilling the radiator), i can hear the hissing again, and i notice it's coming from one of the small heater hoses that's beind the upper intake.
that's that...
i turn the heater off to see if it only leaks when it's on, and it does. no biggie, dont' use the heater.
what caught my attention, though, was yet another huge puddle underneath the car.
i didn't hear it splash on the ground, nor did i see any more leaking after it did, so i'm wondering where the hell it's coming from.
it looked like too big of a leak to come from the heater hose (which was leakign mostly steam), and it only leaked out that one time.
i let the car idle forever, and even took it for a spin, and the temps were fine after just refilling the water level.
where's it coming from?? all my hoses up front are good (minus the above mentioned heater hose), and i couldn't see any leaks from underneath.
any ideas?
today:
that's that...
any ideas?
