  • SN95 4.6L Mustang Tech
Which Chip to get....
  • Thread starter Thread starter 97GTSTANG
  • Start date Start date May 6, 2004
97GTSTANG
852
Virginia
May 6, 2004
  • May 6, 2004
I was thinking of getting a chip tuned for my car.
The Mods are
3.73
bassani x/FMS shorties
2002 5.4heads/Intake
Zex nitrous Kit.
I was thinking of having two programs tuned, one for nitrous and one for N/A
So maybe on N/A have it burned at 14% and when i am ready to use the nitrous i can use a flip switch and drop the timing down to 9%.. any suggestions.
Any one chip better than the other?
I saw this on Ebay. is it any good?
http://cgi.ebay.com/ebaymotors/ws/e...tem=2476645925&category=33597&sspagename=WDVW
Thanks
97GTSTANG
852
Virginia
May 6, 2004
  • May 6, 2004
any suggestions?
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 6, 2004
  • May 6, 2004
Get it dyno tuned since you're going with spray.
EDIT: Since you want to have two programs, one for nitrous, one for n/a, I suggest going to the dyno tune and getting two tunes on a flip chip. One for n/a, and the other tune for the spray. Little more expensive, but definately worth it.
Go HoTO!
602
Mountaintop, PA
May 6, 2004
  • May 6, 2004
SCT!
You can get either a chip with a flip switch or a flasher where you download program to your car. The chips can also be dyno tuned by a authorized programmer.
Check out www.modulardepot.com and check out the cool SCT stuff. Call them in the morning and they can help you make a selection. This is probably the most respected chip/flasher is the business.
Bullitt_#1346
767
Atlanta
May 6, 2004
  • May 6, 2004
I recommend going to your local dyno tuner that has a dyno and does programming. Use whatever chip he uses. He can tune the car on the dyno for n/a and then a separate tune for nitrous. That is the safest way to go. Mail order chips are just best guesses.
mustang35thann
354
Rochester, NY
May 7, 2004
  • May 7, 2004
There are a couple of chips that you can use and have the "flip" option. (listed in no particular order)
1) Autologic
2) SCT
3) Jet
Personally I like 1 & 2 the best. Both you can have done at a dyno shop where they can adjust all the necessary settings including a/f curve. I'm actually selling an autologic chip. If your interested PM me.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
How to get a tach signal for N2O RPM window switch.
  • drofdeath
  • Oct 6, 2023
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2023
drofdeath
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
