I'm going to go against the grain here. I don't like CF, we saw several grenaded ones at the shop when I was there. They're overpriced, and those little couterweights are a gimmick. That being said, their service is great- they always sent free replacements under warrantee.You just get sick of changing them, free or otherwise. Granted, these were in completely different applications, not Mustangs, but they were CF DF clutches.
That isn't my posting point though. What exactly is it about the King Cobra that you love? I've used CF DF, two FRPP KC's, a SPEC, McLoud, Ram, and one or two others in my stangs, and there is no other clutch that works quite like the KC. (that isn't to say I like it, I don't) Regardless, the KC has a different design pressure plate which allows it to have full pedal arc modulation while still grabbing right off the floor. If you like it grabbing that low, it will be difficult for you to get any other clutch (that I've used) to feel the same. IMO, a properly set up clutch should engage/disengage halfway through the pedal arc, and the KC doesn't. If you like that, the KC is your clutch.
I don't, however, know what the torque rating is on the KC, which I inferred was the reason behind your question. I believe it will hold up fine to the engine build you're specifying without any problems. If you're looking for a stronger clutch that will still grab right off the floor, I won't say they don't exist, I just don't know of any.
