Which cooler line is the return on the AOD?
The Shape
2,224
East ARKANSAS Delta
Going to install my B&M cooler tommorow and I need to know which line is the return to the tranny. Is it the one at the top or the bottom of the radiator? I assume it would be the bottom one letting gravity help the tranny pump the fluid through the radiator, but figured I would ask to make sure. Thanks
Yes, the AOD return is the lower fitting on the transmission. The AODE/4r70w return is the upper fitting. Look to the trans for this as someone "may" have altered the lines at the radiator somehow.
I personally run my B&M in series with the OEM cooler in the radiator. I just do it to get more cooling capacity for the most part. I supposed the cold day thing is a concept, but, they generate enough heat to take car of themselves I think.
We often run coolers on their own when the radiator unit has clogged or is contaminated to where we worry about some material possibly breaking loose at some point and getting into the trans.
I think you're on the right path provided you locate the new cooler out of the airstream of the radiator/condenser (under the car). Run hot fluid from the tranny to the new cooler first, then to the radiator cooler, then back to the tranny. In hot conditions, you'll knock most of the heat out with the new cooler significantly reducing the load on the radiator. When in traffic (no air moving across the new cooler) your radiator connection will provide enough cooling for you to keep the tranny happy. In the winter, if your new cooler is 'overcooling', your radiator core will put some heat back into the fluid for you. I think that's a very elegant solution if you're not gonna run some kind of t'stat to keep from overcooling the fluid.
