Which Cylinder Heads?
I might be going another route, instead of my stock heads with port work I think In going to go the aluminum route. I know Trick Flow heads are killer, but they're also very pricey. Anyone ever run the Patriot heads? Ive heard on these that the springs supplied with them dont have enough pressure and need to be upgraded is this true? Also what about Pro Comp heads? I know the Pro Comp rockers are dog **** and assume the heads are also. My motor has an F303 cam with stock bottom end and windage tray. Also going to be running a Edelbrock Victor Jr with this setup will I have any problem with fitment on any of these heads? Thx Chris
honestly...i would spend the extra coin and just get the edelbrock vic jr. head to match... have the lower matched to the heads and you wont be disapointed...im going full vic jr ion my next engine...need the flow for my turbo
I had a link for a head flow chart with all the major heads.... can't find it but will look for you.
I've recently decided on going w/ the Victor Jr's b/c they're a little pricey but for the money its a great deal compared to some of the heads on the higher end. eg. Trick flow
The Patriot heads springs are good to 550 lift and they out flow the Edelbrock vic jr. Pro Comps are junk imo I talked to a few guys and they liked the Patriots just remeber they have 2.02/1.60 val's for clearing them
Look how good they done with the LS1'S and the 4.6 2v ?
Go to the edelbrock rpm.. or the ported GT40 and E7TE's ... IF yo go crazy on flow numbers... I'll be kick'n your ass in the mud!! It is flow, not volume that make the winner...
Just me.....................................
Thumper
