which dist?
  • Thread starter Thread starter steel1212
  • Start date Start date Oct 27, 2004
steel1212
1,180
Frankfort, Ky
Oct 27, 2004
  • Oct 27, 2004
I've got just a stockish vacum advance points dist and was wanting to upgrade. I don't want something that is going to be finicky starting and all that but I want performance from the dist down to the wires.
"Whatcha y'all gots"
66HertzClone
428
Central New Jersey
Oct 27, 2004
  • Oct 27, 2004
I used the MSD ready to run dizzy and blaster 2 coil on my stroker. I picked this model over the others because I did not want to be required to use the MSD box. It can be used if wanted but is not required.
Max Power
1,774
St Paul
Oct 27, 2004
  • Oct 27, 2004
The cheapest way would be to put a Pertronix in the dizzy you got to eliminate the points. Don't even have to pull the sucker out to install.
skywalker
733
Pensacola, FL
Oct 27, 2004
  • Oct 27, 2004
I had a stock dual advance dist with breaker-points. Sucked.
I added pertronix and it was pretty good.
I added a full MSD system and dist and WOW!
dolfan87
1,242
Lake Havasu, AZ
Oct 27, 2004
  • Oct 27, 2004
Davis Unified Ignition.
Eliminate the external coil, one wire hook up, and you're ready to rock.
87
Jester67
908
TN
Oct 27, 2004
  • Oct 27, 2004
Is the Pertronix II any better i.e. worth the price difference over the original Pertronix?
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Tunerstudio help / services
  • Kabuki_notch
  • Apr 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum May 2, 2026
Mustang5L5
J
Which cylinder is which? 3.8L 2004
  • joeybuddy96
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 24, 2026
joeybuddy96
J
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
