Which Efi System?
  • Thread starter Thread starter 65FBE2
  • Start date Start date Jul 14, 2012
65FBE2
283
Minnasnowta
Jul 14, 2012
  • Jul 14, 2012
I need some advice. I have a 289 a code with the stock Autolite carb redone by Pony Carbs before they closed. The carb is a work of art and I don't want to keep using it. I want to keep in it's concourse condition. The car is a driver and I am looking for a turn key kit that works. What have some of you guys used that has worked well? The motor has Doug Tri-Y headers and comp cam dual energy 214/223 @ .05 and .490 lift. Protronix in stock distributor. 3.25 gear with a T5Z
65FBE2
283
Minnasnowta
Jul 14, 2012
  • Jul 14, 2012
Let's try this, has anyone used FAST EZ EFI? Or Procomps system? I would be great full for any feedback
bartl
217
West Rutland, Vermont
Jul 14, 2012
  • Jul 14, 2012
Why not just get another 4100 and send it to Kurt Praxl (aka VMF "carbontooters") and have him go through it? If you're bound and determined to do EFI just bear in mind the requirements for some systems (electric fuel pump location, line size and construction, return lines needed, sensors needed, manifold, regulator, ECU, etc.
P
PhilJustPhil
36
Ottawa
Jul 15, 2012
  • Jul 15, 2012
I installed a Powerjection III system this spring and wrote it up in this thread:
http://www.stangnet.com/mustang-forums/threads/efi-conversion-experience-long.856312/#post-8614002
65FBE2
283
Minnasnowta
Jul 15, 2012
  • Jul 15, 2012
Nice thread! It was very helpful. Big question, if you had it to do over again, would you do it the same way? What if any MPG improvements have you noticed?
rbohm
6,698
550
204
tucson,az
Jul 15, 2012
  • Jul 15, 2012
the easiest efi systems are going to be those that bolt in place of a standard four barrel carb, and have the capability of learning the engine on its own rather than you actually having to hook up a laptop or other device to tune the system. the holley projection is a good one to use, among others. as to fuel economy improvements, you might see 2-3 mpg due to the tighter control of the fuel mixture, but dont expect anymore than that. and even that is the best you can expect.
P
PhilJustPhil
36
Ottawa
Jul 15, 2012
  • Jul 15, 2012
P
PhilJustPhil
36
Ottawa
Jul 15, 2012
  • Jul 15, 2012
Can't comment on milage, and still have a way to go in terms of tuning for peak performance... the Adaptive Learn is pretty good, but benefits from some additional tuning. For it to "learn" it has to spend a bit of time in each RPM/MAP cell, so as it "learns" full throttle at first there is a lot of stumbling and popping until it narrows in on the tuning.
Currently I'm trying to fine tune the cold start parameters as it needs a bit of work there. But once started it runs fine. The big improvement to me is drivability while the car warms up. All the old bad habits of the (electric choke) carb are gone. Start it, and it runs great right away. This is really noticable in colder weather.
iskwezm
4,159
20
79
Rowland Heights,California
Jul 16, 2012
  • Jul 16, 2012
I have had the Powerjection III for about 3 years now with no issues.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 17, 2012
#10
  • Jul 17, 2012
  • #10
Is there something wrong with the Ford factory mass air system ? EEC-IV with a moats and a good tune can do wonders.
golf4283
1,253
Orland Park, Illinois
Jul 17, 2012
#11
  • Jul 17, 2012
  • #11
I agree with Rusty. I went with the stock ford Mass Air setup with an A9L computer in my car. Parts are cheap and redily available over the counter or at the junkyards and you have yourself a geniune Ford product in your car.
The aftermarket systems all look nice as well but just seem too pricey for my taste. I put together my EFI swap for about $450 which included all the sensors, intake, throttle body fuel injectors etc.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 17, 2012
#12
  • Jul 17, 2012
  • #12
A little tip, you can flip the upper intake manifold 180* to run the TB out the the passenger side if you don't want to relocate your battery.
rbohm
6,698
550
204
tucson,az
Jul 17, 2012
#13
  • Jul 17, 2012
  • #13
the only issue with the ford factory efi system is that it is limited in stock ford to mild modifications. there are tricks you can use like higher fuel pressure, large mass air flow sensors, larger fuel pumps, etc. the EECv would be a better choice imo.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 18, 2012
#14
  • Jul 18, 2012
  • #14
Was the 94-95 Mustang EEC-V or just EEC-IV with EDIS ?
Thats why I sugested a Moats quarterhorse to tune the factory unit. It is still cheaper then going aftermarket EFI and it is mass air.
PoppyMod
617
Severna Park, MD
Jul 21, 2012
#15
  • Jul 21, 2012
  • #15
Hi,
As was noted with the Powerjection III system, It would be helpful to have documentation posted noting the procedure, parts, and comments after the install etc., adapting the Ford systems to our older junk. I did this for the 65-66 T5 conversions and has been requested numerous times.
It's a nice learning and training exercise.
blown65
1,938
Queen Creek Arizona
Jul 21, 2012
#16
  • Jul 21, 2012
  • #16
The factory ford is a nice inexpensive way to go, but I personally dont care for the look of it on a classic.
Buddy just did the EZ-EFI and that works nicely. No ignition control however.
I'm not familiar with the others.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 21, 2012
#17
  • Jul 21, 2012
  • #17
Most of the aftermarket systems are speed density and require a lot more tuning. For a daily driver application mass air is better. If it is a hot rod/race car or weekend cruiser then speed density is just fine.
blown65
1,938
Queen Creek Arizona
Jul 21, 2012
#18
  • Jul 21, 2012
  • #18
That's true to a point but that ez-efi was very easy to setup and required very little tuning. It does pretty good at self learn and would be much more forgiving than a mass air system when you start adding cams and other crap that throws a tune off. At least the FAST is always trying to learn.
He installed it on a Flat Head ford that made 120rwhp, not exactly a race car.
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
