Which Engine combo???
SHOWTIME!!
15
There are a few motor combo's that i am trying to decide on. ALL of them with use a set of heads that have been ported to flow [email protected], a set of Trickflow stage 2 cams, BBK long tubes, and a corresponding O/R X pipe.
Combo number 1:
Teksid aluminum block
DSS all forged internals 4.6
10:5 compression
Combo number 2:
MMR 600 4.6 short block
10:5 compression
Combo number 3:
Proline 5.0 stroker
Use my block
10:5 compression
I still plan on using nitrous. I am going to step it up to a 150 shot this time. I am adding a 255 fuel pump tho to be on the safe side.
But, i have also thought about throwing the nitrous away, and going all motor and using the HiTech stage 2's.
I just dont know what to do, i need some opinions and suggestions.
I would choose something with a lower compression...something below 10:1...you may put a blower on someday...and you will be glad you did if you go with a lower compression up front..
Get Forged under any circumstances...no exception to that..
Other than that..you won't go wrong..
