Which Engine?
  • Thread starter Thread starter 87_5.0
  • Start date Start date Nov 10, 2005
87_5.0
73
  • Nov 10, 2005
I need to know what is going to give me the most power and fastest quarter mile times. im going to list all the parts i have. Can you guys please tell me what to do.
-302 block or 306 block
-NX nitrous, or a powerdyne supercharger (6 psi)
-F303 or B303 Cam
-351 heads or stock 302 heads
-19 or 30 lb injectors
-GT40 or Trickflow street heat upper and lower
Can you guys tell me what combination will be the best? Thanks,
Brent
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 10, 2005
  • Nov 10, 2005
Going fast down the track isn't about having the biggest parts... It's about having the right combination. If you can drive, have a great suspension setup and a few bolt-on's you can hit the 13's.
You really need to decide what type of power adder you want to run before most people will comment. NOS is good, but it's not a full time thing and you'll end up wanting to drive around with it on all the time. S/C's are nice but you'll need a good tune to get the most bennifit out of the set up.
If you run a S/C you won't want to use a cam that has a lot of overlap (the S/C will blow your fuel out the exhaust)
If you run NOS you will want a little overlap to help scavange the mixture into the combustion chamber.
Buy a decent set of aftermarket heads and you won't have to worry about assembling the springs, valves and retainers.
Rockers, lifters and pushrods are pretty easy to install. Rockers need to be toqured properly, but it's not hard to do. The lifters just drop into the bores.
5.0ina66
664
Ohio
Nov 10, 2005
  • Nov 10, 2005
Pick power adder, then that will determine which cam and what size injectors. I'd use the Trickflow intake...the GT40 ain't that great. Definatley use the 351W heads, and porting them would help a LOT.
302/306......Potate-o/Potato
Edit: I've seen people run low 13s/very high 12s on a bone stock 5.0 with headers...it's all in the suspension setup!
87_5.0
73
  • Nov 10, 2005
Which combination would be best with the nitrous, and which combination would be best with the supercharger?
T
tjm73
2,418
Rush, NY
Nov 10, 2005
  • Nov 10, 2005
You questions are too general. Do you want to have the power all the time with a superharger or just on demand with the nitrous? You have to tell us where you want to be in order for us to offer an opinion on how to get there. Plus we need to know if you are anti this or that. Some guys hate the alphabet cams & won't run them, others hate NOS, some guys are strickly natural aspiration or nothing (that's me ), still others are die hard Vortech or Procharger guys.
You really need to asses what you want to run and see what you need to make your entire combo work to deliver that goal. What kind of budget do you have? Do you already haev parts or are you startign from scratch with a totally clean sheat of paper (so to speak)?
87_5.0
73
  • Nov 10, 2005
I already have all of those parts. What i ran this year is in my sig. I have two cars...one with a charger and one with nitrous, but i have both of them stripped down and all the parts that i listed are laying around. I want to know what parts i should use together if i were to build a supercharged engine, and what parts i should use together if i were to build a nitrous engine. thanks,
Brent
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
