Which gaskets do I NEED for the PI headswap? Those who have did it come in...
5spd GT
"the 5.0 owns all"
9,516
Arkansas
I know I will need headgaskets - what is the price/part number?
Intake gaskets - What is the price/part number?
What other gaskets will I absolutely need to replace?
alot, got access to a fax?
head gasket 4C2Z-6051-AA & BA @$100.00 each
intake YL3Z-9439-BA $20.00 PR
then thers exhaust gaskets, frt cvr gskts, o-rings for the water pump and theremo, head bolts are @$60.00 a set coolant tube and nipple, dip stick tube, alt brkt(these are wholesale prices, not list)
I see on 50resto (latemodel restoration)...they have a head changing kit for $105 bucks.
It includes - headgaskets, head bolts, exhaust gaskets, oil dipstick tube, and Randy what is the other thing in the picture? There are 4 of them?
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M6067D46 1&comp=LRS
They also sell the alternator bracket for $15.
LRS sells the 99-04 intake for $190 bucks. It has the aluminum crossover. Does the 99-04 intake fit on 01+ heads or are there differences between the 99,00 and 01+ intakes/heads?
those rubber tubes are to go around the outward head bolts to hold them above the deck of the block when changing the heads wth the engine in the car. also of note, that head swap kit does NOT contain the best head gaskets, is not complete as far as needesd gaskets go, was not designed for the "PI" swap and carries NO waranty
1999 up ALL PI heads heads have the same shape intake port and just about ALL PI car intakes are of the same square port design
