which gear install kit?
tony laq
121
ive pretty much decided to get some gears ...now im seeing that most sites offer 2 or 3 different install kits? ive got a 2002 gt with 31k on it - so which one do i get :shrug:
also..how off is my speedo going to be? i assume im going to have to buy a speedo recal also?
thanks...tony
you need the full kit with bearings, shims, ring bolts,grease, and marking compound. it's better to just put the new bearings with new gears due to the fact you have to pull the old bearings off that are pressed on which could damage them. pluss it's cheaper to do it now than if an old bearing breaks due to damage from trying to pull it off the stockers. mustang tunning has the sale on gears rite now too. so check them out. and go at least 4.10 if you wanted to know my gear ratio opinion. :nice:
