  • 2005 - 2009 Specific Tech
Which gears to buy??
  • Thread starter Thread starter LawlessJay
  • Start date Start date Jan 30, 2008
1 of 2 Next Last
L
LawlessJay
10
  • Jan 30, 2008
I have an 07 GT. I drive the car everyday but only about 100 miles a week. I'm thinking about 410's but not sure. And which brand do people like more. Thanks
steedman07
176
Connecticut
Jan 30, 2008
  • Jan 30, 2008
Motorsport gears, and go with 4:10's..I have an auto with a Vortech, and drive alot of highway and love 4:10's..I gained top end speed by going with a 4:10..You will love them...
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Jan 30, 2008
  • Jan 30, 2008
I have 4.10s in my automatic and have put about 27K miles since last March with them and absolutely love them! If you can come across an older set of FRPP(not Motive)gears then you will be better off as the new ones are not as good of quality.
R
ranger04
245
  • Jan 31, 2008
I'm running 4:30's with a 5-speed, these 3 valves love to rev, so you can throw some gear at it. Even with 4:30's it doesn't run out of steam when you trip the lights. Steeper gears can even save wear and tear on the clutch if you do alot of around town driving for those with manuals. I would at least go with 4:10. I used ford racing gear set and have had no problems, very quiet.
88-378
14
Alpharetta, GA
Jan 31, 2008
  • Jan 31, 2008
?? i just purchased a set of 4.10's from 50resto. they are FRPP. On the box it says made in Italy and they are micro polished.
If your not familiar with how the Italians machine quality steel I would take another look.
ufnavy06
292
Jacksonville, Florida
Jan 31, 2008
  • Jan 31, 2008
So consensus is 4.10s are the way to go? Just toss them in there?
O
o0Dan0o
485
  • Jan 31, 2008
I would get a shop to do it, unless you or someone helping you knows exactly what you're doing. I'm going to go with 3.73s, but I also plan on going with a lower tire profile which will put me about half way between 3.73s and 4.10s on the stock tire.
Dan
BLKNED
67
Jan 31, 2008
  • Jan 31, 2008
How bad have the 4.10's hurt gas milage. When I pick it up my Mustang will be my daily driver so mpg is a concern for me. Also would the 4.10's be a real big jump from the 3.55's with a manual car?
kooldawg6
Aug 31, 2006
1,679
Central VA
Jan 31, 2008
  • Jan 31, 2008
Mine is the auto with 4.10s and I avg 19-20 with mixed driving and 24 on a gentle long cruise on the highway.
kooldawg6
Aug 31, 2006
1,679
Central VA
Jan 31, 2008
#10
  • Jan 31, 2008
  • #10
Those are the newer ones. A local speed shop that specializes in Stangs has had problems with these making noise. Mine are the older FRPP gears and I've never had an issue with mine and he had done nearly 2 dozen S197s by the time mine rolled through. I believe it is due to the materials they use in the S197 clutch packs that is the main culprit. Good luck with them.
Blueflash454
Oceanside,NY
Jan 31, 2008
#11
  • Jan 31, 2008
  • #11
Ford 4.10's
mhanksii
336
Maryland
Feb 1, 2008
#12
  • Feb 1, 2008
  • #12
I know my tires suck (Fuzion 255/45-17 ZRI's) but wouldn't 4:10's make 1st gear all but worthless around town? I had a 5.0 with 4:10 (I know these cars like more gear then the older ones) and I would drive around town starting in 3rd and the only time I could use 1st was with slicks and a good track. Any advice would be great as I am thinking about getting some gears from JPC to add to my drive shaft I have on the way! Also would a drive shaft + 3:90/4:10's be enough for .5 sec in the 1/4?
kooldawg6
Aug 31, 2006
1,679
Central VA
Feb 1, 2008
#13
  • Feb 1, 2008
  • #13
Worthless in town? No, but shifting quite a bit and quickly. With good traction, I don't see why you couldn't reduce .5 off 1/4 times with gears/ds.
mhanksii
336
Maryland
Feb 1, 2008
#14
  • Feb 1, 2008
  • #14
so what difference would there be in 3:90 and 4:10?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Feb 1, 2008
#15
  • Feb 1, 2008
  • #15
i have 4.30s and its not bad on the street. traction is limited, but for normal street driving, its fine.
blacksheep06
288
#16
  • Feb 1, 2008
  • #16
I use 1st all the time with 4.10's, there's not that big of a difference going from the stock 3:55 as far as normal driving around town goes.
Punch it though and you'll run out of 1st really quick with 4.10's and the aluminum DS.
kooldawg6
Aug 31, 2006
1,679
Central VA
Feb 1, 2008
#17
  • Feb 1, 2008
  • #17
Depends on rear tire height and what your trap RPMs are. Seasoned drag racers squeezing every last drop out of the car could tell, but most of us may not be able to notice a thing. To me, saying 4.10 just sounds better
bigcat
what size rear tire are you running and how are highway cruising speeds(70-80MPH)?
bigcat
May 1, 2005
3,015
7200 feet
Feb 1, 2008
#18
  • Feb 1, 2008
  • #18
stock tires. have not been cruising on the interstate yet. still breaking them in.
ufnavy06
292
Feb 2, 2008
#19
  • Feb 2, 2008
  • #19
Dan
Well of course. But if I'm going away from my stock 3.55 (right?) going to the 4.10 is a shorter ratio thus improving acceleration by gearing the car more for that instead of top end speed? It seems everyone has the 4.10s, is that just because it provides a descent ratio for street drivability?
mhanksii
336
Maryland
Feb 2, 2008
#20
  • Feb 2, 2008
  • #20
My worry is about forced induction, I plan on bolting on a Paxton 9lb blower, would it be possible to get any traction in 1st with that kind of power on tap? I'm not the best driver but not the worst either, just worry about going through more tires than I do already do.
sorry for high jacking this tread a little, but anyone with advice on how to build a 12.00 car with street manners, I am listening.
1 of 2 Next Last
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
D
Hey Ya'll from the North Georgia mountains
  • dulcimerbob
  • Sep 11, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 18, 2026
John redcorn
J
