Which gears?
  • Thread starter Thread starter u0061914
  • Start date Start date Sep 11, 2009
U
u0061914
54
Prior Lake, MN
Sep 11, 2009
  • Sep 11, 2009
I have started my I6 to v8 conversion this week. In the process found a fairly built 289 (cam and some headwork) with an AOD which was in another 67. I also picked up a 9" from a 69 Mach 1. The 9" alegedly has 3.00 gears in it. I also have a 9" 3rd member with 3.50 gears in my parts shed. With my setup, which are the preferable gears? I'm tinking that the 3.50s might be better with the overdrive. Any thoughts?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 11, 2009
  • Sep 11, 2009
Absolutely use the 3.50.
golf4283
1,253
Orland Park, Illinois
Sep 11, 2009
  • Sep 11, 2009
^^^ What he said. With that overdrive gear you'd be dumb not to go with a higher rear end ration.
mr408
11
australia
Sep 13, 2009
  • Sep 13, 2009
Yep , go the 3.50 , you still will only be doing about 2000rpm in overdrive with 3.50 at 60mph, depending on your wheel and tyre diameter.
68stang351
850
9
39
Savoy TX
Sep 13, 2009
  • Sep 13, 2009
You wont like it with 3.00's in it.
armand67Fstback
146
  • Sep 13, 2009
Another vote for the 3.50s here.
rbohm
6,698
550
204
tucson,az
Sep 13, 2009
  • Sep 13, 2009
one more vote for the 3.50's
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Sep 13, 2009
  • Sep 13, 2009
+1 for 3.50s.
calpolymustang
217
Santa Rosa, CA
Sep 13, 2009
  • Sep 13, 2009
I had a 3.40, but it seemed to be running a little too low with my 25.2" tires and .67 overdrive gear.
Now I have 4.11s, and ZERO regret. At 65mph, I'm spinning 2300; at 75, 2600rpm.
The response of the car taking off from a stop is much better. Keep in mind 1st gear is only 2.46:1
tx65coupe
Sep 13, 2009
#10
  • Sep 13, 2009
  • #10
With overdrive definitely the 3.50 gears over the 3.00 gears.
57fairlane
560
Oakwood, GA
Sep 13, 2009
#11
  • Sep 13, 2009
  • #11
3.50, but you could easily go with more gear.
6Stang7
1,470
Livermore, CA
Sep 14, 2009
#12
  • Sep 14, 2009
  • #12
He speaks the truth. I have 4.11's in the 67 and I run around 2k on the freeway. Get the 3.5's.
RGS0907
429
New Jersey
Sep 14, 2009
#13
  • Sep 14, 2009
  • #13
4:11s have a way of making you smile
U
u0061914
54
Prior Lake, MN
Sep 14, 2009
#14
  • Sep 14, 2009
  • #14
Thanks all. I'm now thinking that I may skip both and regear to 3.73 or 4.11s. They way the money is flowing into this project, what's the cost of a ring/pinion, etc!
blown65
1,938
Queen Creek Arizona
Sep 14, 2009
#15
  • Sep 14, 2009
  • #15
I'd go no lower than 4.11's. Even with 4.56 gears and the AOD your looking at 2500 rpm at 65-70mph anyways. Just depends on the rest of the combo, but I love the 4.56's/AOD combo in the Shelby.
3.0 or 3.50's, no thanks.
C
Suggestions for rear diff gears - 1969 Mach 351W 4v
  • cfauvel
  • Apr 8, 2024
2K
Classic Mustang Specific Tech Jun 27, 2024
cfauvel
C
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
I'm a new member...
  • Badcatt
  • Feb 4, 2023
  • The Welcome Wagon
The Welcome Wagon Feb 19, 2023
Badcatt
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
