Which headers to buy?
  • Thread starter Thread starter 66bluefb
  • Start date Start date Oct 16, 2004
66bluefb
164
okla.city,okla
Oct 16, 2004
  • Oct 16, 2004
I am going to buy some new headers and flowmasters for my 66 stang.I was looking though the Summit book and they range from 89.00 to 300.00 or more. What is the difference between the cheaper priced and the higher ones? Is it performance?
Thanks, Tony
Sicarius428
2,085
Oct 17, 2004
  • Oct 17, 2004
What you are paying for is fit between the flange and head and what coating you get. The fit of the flange to the head is pretty obvious. The better the fit the less leaks=more power and the less work to install. The other main thing which is very expensive is the coating on the header. The ceramic or Jet coating option is definately the way to go for longevity. The heat from the headers will bake off the paint pretty quick exposing the bare metal to the elements. Your headers will look pretty nasty in a very short time and probably will need to be replaced in a few years. Please forgive me but I am assuming that you are looking at long tube headers. If not please consider them because they will give you more power. Another option that I forgot to mention above is the primary and collector size. The larger primarys will give you more high end power and the smaller ones will give you more torque as a general rule... Choose according to what you are trying to do with your engine. For a small block, low end torque is a good thing. Collector size is how big of an exhaust you are going to run. 2 1/2 inch is pretty good for a small block. There probably wont be much of an HP gain but you might loose some torque if you go with the 3 inch. I suggest looking at Hooker Super Comps w/ceramic coating and BBK long tubes w/jet coating. They are expensive but you really get what you pay for. Hope that helps.
Kevin
blascrw
191
Opelika, AL
Oct 17, 2004
  • Oct 17, 2004
TRI-Y's
I highly recommend the tri-y's..
1. they were designed and made specifically for stangs...
2. they still allow great ground clearance
3. they were originally on shelby's so there is still the nostalgia
4. they are inexpensive...
I got mine from MustangsUnlimited...good price, fast shipping.
If you get tri-y's from a mustang vendor they likely are all the same.
Go for the ceramic coated...will pay off in the long run besides looking good.
I posted some pics of my ceramics when they came in, before installing them...
http://forums.stangnet.com/showthread.php?t=500343
Ron
HistoricMustang
2,359
Confederate States of America
Oct 17, 2004
  • Oct 17, 2004
The goofy looking guy is back and I am betting he will soon be history!
Try to stay away from tri-y's as they have a lot of welds and welds tend to fail after going through a lot of heat cycles.
I missed some races before the light went on.
HistoricMustang
www.historicmustang.com/tech.html
one2gamble
902
Monterey
Oct 17, 2004
  • Oct 17, 2004
the hedman elites hang to low in my opinion
G
GaPonyFarm
663
Columbus, GA
Oct 17, 2004
  • Oct 17, 2004
I got the ceramic coated Tri-Y's from Virginia Classic Mustang for $249. I had the Chrome Tri-Y's from Mustangs Unlimited and they blued much too easily. The ceramic coated headers fit and look great!
347Fastback
340
Central Coast
Oct 18, 2004
  • Oct 18, 2004
I have had the tri ys and the hedman elite. I am currently using ceramic coated patriot headers. They are not shortys and not exactly long tubes. They are perfect for people who are using a clutch cable with the 5 spd swap....
Sicarius428
2,085
Oct 18, 2004
  • Oct 18, 2004
Oh ya forgot you might want to stay away from 3 inch collectors too... They kill your ground clearance. There is aways a time when you had that extra half inch or so if this is going to be a street car.
Kevin
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
T
Resolved Exhaust/Muffler tips
  • Tom77
  • May 9, 2025
1965 - 1973 Classic Mustangs -General/Talk- May 9, 2025
Tom77
T
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
