Which Heads ?
  • Thread starter Thread starter Stangninjak
  • Start date Start date Nov 9, 2005
Stangninjak
324
  • Nov 9, 2005
I just became the proud new owner of a 65 coupe Screaming yellow, with a nice black <vynal ?> top. The engine is a 351w.
Now so far the engine has
edelbrock Preforma 351-w Intake
edelbrock Preforma 600cm Carb /w electric choke #1406
Hedmans Long Tubes Headers.
MSD Ignition, Coil.
The Heads are what I am wondering about. I was told that they were "shved heads" but I think they may be the stock steel heads..not exactly sure yet. If I want to replace them, what would be a good set of heads to toss on ?
Victor JR ? Trickflow Twisted ? Do I need to upgrade the intake and carb ?
I am comming out of a 2003 Cobra, STOLEN and I found this car in really good shape. Was to good of a deal to pass up, so Old School is the way I am going now. I will admit though, I have not seen a carb engine in a looooooooong time. Doing my homework to catch up, and any info I can get would be very helpful for this noob owner !
Thanx in advance.
jasonn
316
By Rochester MN
Nov 9, 2005
  • Nov 9, 2005
Really depends on what your goals are for the car. Nice street cruiser with good gas mileage but a little power, street car that will race once in a while, serious street car with no gas mileage, or race? A nice bolt on set of heads that would help alot would be the performer or performer rpm heads for a mild windsor. Do you plan on running different gears, converter, big cam, things like that??
Stangninjak
324
  • Nov 9, 2005
More on the lines of a street car that can handle a race every now again. I use to take my Cobra to morosso every now again, so I guess I am looking for something around 400ish rwhp. Heh something that can stand up to the tradition the stangs put down. As always, I sure hell do not want any ricers to take me out..man I could never live that down driving a classic Stang.....
J
Jc69Stang
95
  • Nov 9, 2005
AFR 185cc should do it for ya. But make sure the cam is up to the task of 400hp.
D
D.Hearne
11,730
south louisiana
Nov 9, 2005
  • Nov 9, 2005
Stick with choices that have no larger than 1.94 intake valves, unless you know for sure that the pistons that are in the motor now can handle larger ones. 1.94's are plenty large for most street applications.
classic boost
709
canton, oh
Nov 9, 2005
  • Nov 9, 2005
afr185, performer rpm, twisted wedges.
check p-v clearance.
94CobraPace
907
Houston, Tx.
Nov 9, 2005
  • Nov 9, 2005
Any of the aftermarket heads (AFR, Edelbrock, TW, holly, Brodex) will perform well & make power. Need to match the combonation & have a goal for the power level you are wanting, along with how high you want to rev the engine. As stated, just check piston to valve clearance.
Edbert
3,548
32
109
Austin TX
Nov 9, 2005
  • Nov 9, 2005
400 at the wheels is gonna take some effort and money. A power-adder is probably in your future unless you stroke it or seriously reduce its streetability.
One of the problems is that to get the 400rwhp figure you're gonna have to really rev it up and the big Windsor's are not known for their revability.
I'm not saying you can't do it by any means, you definitely can but you're gonna want ~500hp at the flywheel to get there and that is gonna cost you.
The stock heads are iron not steel, and not only do they have to go but so does that carb and that intake, you wont even get close with them. Get the 185s (maybe 205s), build the crap outta the bottom end, get a cam with 0.6 lift and ~300 duration, a tall single-plane manifold and a Holley 850 and you'll be close. Just give up on any thoughts of air conditioning or power brakes. If you have an automatic it will need a full performance build and a stall in the 3500 range.
Stangninjak
324
  • Nov 10, 2005
Thanx for the replies guys. I am looking into my parts list now, and I guess the first thing I need to do, is a get a baseline of what the engine puts out right now. So its off to a dyno soon. With this type of info comming in, I will soon get a better understanding of what this type of setup is capable of.
12sec67
1,301
San Diego, Ca
Nov 10, 2005
#10
  • Nov 10, 2005
  • #10
one good thing about having an old mustang...
they are a hell of a lot lighter - 2500-2600lbs for a 66 -then a 2003 mustang which is somewhere around 3300lbs.
if your not to comfortable with a carb and want to go back to EFI there is plenty of info on this site to do the swap
BTW --- sucks your cobra got stolen!
5.0ina66
664
Ohio
Nov 10, 2005
#11
  • Nov 10, 2005
  • #11
A custom cam (or well-chosen manufactured unit), ditch the intake in favor of a PerformerRPM or Wieland Stealth. AFR185s or Trickflows, make sure the compression is nice and high, and I could see 420hp and about 375RWHP. Add a small shot of spray, and volia!
400RWHP is going to be tricky for an N/A street 351W though. I suppose you could go for a 750cfm carb and a Wieland Xcellorator intake to gain a bit more street-friendly HP.
PS: You could always go EFI with a Trickflow intake and 5.0 MAF system. Then, strap on a Vortech S-strim
M
mustangman70
1,235
St pete, Florida
Nov 10, 2005
#12
  • Nov 10, 2005
  • #12
AFR185's
/ thead
1979 Camaro
22
#13
  • Nov 10, 2005
  • #13
Heads
I just dynoed the 306 going in my 66 Fastback and I used the AFR 185 heads.
Comp Cams 274 XE roller cam. 650 Edelbrock carb. Roller rockers. Air Gap intake.
10.5 compression
408 HP and 398 torque.
Sounded great on the dyno.
J
Jimmys66
419
Paw Paw MI
Nov 10, 2005
#14
  • Nov 10, 2005
  • #14
10.5 compression
That's a nice little hp return on 306 ci.
Stangninjak
324
#15
  • Nov 11, 2005
  • #15
Hmm see a lot of replies for AFR. Thanx guys. AFR is who ? I am going to look up their website. The Lo-Jack goes in today. I have the paint waxed up, and the chrome polished Pics comming soon.
mrfomoco
108
The Woodlands, Texas
Nov 11, 2005
#16
  • Nov 11, 2005
  • #16
I will get my new motor on the dyno soon...but I have the Trick Flows and dang....I've never been in a car that pulled like this.
1320stang
4,329
23
89
Edmond, Oklahoma
Nov 11, 2005
#17
  • Nov 11, 2005
  • #17
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
