Which ignition system to go with?
  • Thread starter Thread starter Loco5.0
  • Start date Start date Mar 5, 2008
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 5, 2008
  • Mar 5, 2008
Car will be turboed & sprayed. 500+ whp. Wideband, electronic boost controller, etc etc.
Which electronic ignition system would be best for my application?
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Mar 5, 2008
  • Mar 5, 2008
ive heard horror stories about msd. personally im going with a mallory sytem. this is more of an opinion question.
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 6, 2008
  • Mar 6, 2008
I'd appredciate it if folks could tell me why they are recommending the ones they are as well as what they offer over the competition & what their experience has been with whatever units they have used.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Mar 6, 2008
  • Mar 6, 2008
I have an MSD system: 6AL, billet distributor, coil, wires. The only real issue I have had is the ignition module and the distributor pick up. The ignition module went out and I had to replace it. Then about a year later the magnetic pick up went out and I had to dissassemble the distributor and replace the pick up as well.
enyawix
507
Mar 6, 2008
  • Mar 6, 2008
ford coil on plug!
With a little homework you could use a ford coil on plug ignition. off a newer mustang. The ignition in the newer mustangs is VERY hot!
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 8, 2008
  • Mar 8, 2008
ttt
G
Garbageman1234
  • Mar 8, 2008
Having had my MSD distributor crap out right after the warranty expired, I would not recommend one.
88-378
14
Alpharetta, GA
Mar 9, 2008
  • Mar 9, 2008
Mallory is probably one of the top systems out there.
MSD was on top when they were made in US. If you can find an older MSD used, get that.
Loco5.0
5 Year Member
Apr 2, 2005
394
PA
Mar 9, 2008
  • Mar 9, 2008
I'm leaning towards a Mallory system, but I'm not sure which one I should go with.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
