  • 1994 - 1995 Specific Tech
Which injectors do I need?
  • Thread starter Thread starter johnny_munyak
  • Start date Start date Feb 10, 2009
J
johnny_munyak
97
  • Feb 10, 2009
I'm looking for a set of 24lbs injectors to replace my 19lbers for my 95' GT. I see that there are a couple of different kinds.
Which ones do I need? Anyone have a good set they want to part with?
parrish5o
Dirty South
Feb 10, 2009
  • Feb 10, 2009
I've got a set of FMS 24lb injectors that I took off my car when I swapped the 306 for a 347. I'm running 30s now. They have been in my shop for the last three years and I have no use for them.
k00ksta
158
Chicago
Feb 10, 2009
  • Feb 10, 2009
Dont forget your going to need a new MAF with those injectors :]
J
johnny_munyak
97
  • Feb 10, 2009
I realize that the MAF will not longer match.....however the stock MAF on a 95 GT is a 70 MM unit....but calibrated for 19lber. A custom chip can recalibrate the stock MAF for useage with 24lbers.
Or am I missing something?
MysteryMachine
1,835
Parkesburg, PA
Feb 10, 2009
  • Feb 10, 2009
what mods do you have?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 10, 2009
  • Feb 10, 2009
Well ... It may sound like I'm splitting hairs
BUT
No Ford OEM meter is caled for ANY particular size of inj
Also ... A tuning interface or chip does not recal the meter
I won't go into a long winded or boring bunch of details
but
Just to keep things in the ballpark of being kinda accurate
I will say ... From a tuning perspective ............
If your mods don't generate more airflow than the OEM meter's limit
then
You could use 24's or 30's with that OEM meter
The data manipulation is done in the pcm ... don't ya see
Now ... if you wanted to try and get by without a tune
You could go with the Cheat Method which is used by Aftermarket
Meter Manufactures
That method is focused around using an electronic (ProM) or mechanical
(C&L) method of tricking the pcm about the true amount of air flowing
through the meter
You decide how much fuel you will need (inj size)
then
You select a meter that has been "caled" to that particular size of inj
The cheat method works pretty good with 24's ... no guarantees
but
When you move up to 30's or larger
You got a pretty good chance of issues at idle and cruise conditions
cause
The larger size inj's will push out too much fuel
Also ... Cheat Method really hoses up the 94-95 pcm load factor's
BUT
I promised not to go into all that kinda stuff ... Didn't I
Now ... That we've kinda sorta set the record straight
Like Jinx said ... "How could we answer your Q with any kind of
intelligence if we don't know anything about your mods or plans
for your combo"
I'm done now
Grady
J
johnny_munyak
97
  • Feb 10, 2009
Fair enough.
Thumper prepped - ported/polished GT 40s with larger valves
E303 camshaft
65mm TB
Stock 70 mm MAF
Shorty headers (still deciding)
TMOSS Ported GT 40/Explorer intake
This is the short list so far. Was told the 19's won't work because they will be at max duty cycle with the combo. Necessary to go to 24's.....they would be installed with a tune later on once the hardware is installed.
MysteryMachine
1,835
Parkesburg, PA
Feb 10, 2009
  • Feb 10, 2009
WOW Grady saying that I said something important is like a car god saying I'm the greatest gear head ever.
I am happy that he mentioned me though
hmmm I would think maybe going to 30's would be better but Grady would be the one to answer that
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 11, 2009
  • Feb 11, 2009
Kinda short on time tonight
so
I'll just touch on the basic ballpark kinda answer
If one was gonna try and get by without a tune on such a combo
They would most lilely go 24's and use an afpr
If one was gonna custom tune .......
My first choice would be 30's for MANY reasons
but
I'll just hit the important ones
1) You NEVER wanna go lean under heavy load
2) You will be tuning at OEM pressure
therefore
30's act smaller than most peeps relate to when using elevated pressures
3) You can easily tune out fuel at low pulse width conditons like idle & cruise
4) Last but not least ....
Many ... I repeat ... Many ... have seen 24's peter out sooner than they
thought on h/c/i combos ... therefore ... 30's give you room to grow and
allow you to know for sure you are covered under all condtions
As always ... You go the route based on your application :Word:
Gotta Go
Grady
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Oct 15, 2026
skidad
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sunday at 5:31 PM
roldy
R
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
