which is best
lostkid
47
what set of gears will be best for my 94 gt. its an auto. what name brand and how bad will they kill my gas milage. after reading over the threads i have decided i will be putting gears in my car i'm just not sure which ones to get. thanks for all the help.
Ford motorsports are good.....but just to let you know I bought "Motive gear" 3:73's and I havn't "any negative" things to say......except with my auto I am going to make the jump to 4:10's over the winter.......
Drake...what RPM's do you cruise at around 70mph?
Wonder how much higher it would be with 4.10's.
I want to change gears also but I am not sure what I want to go with. I need some gears to complement my e303 badly.
The gear question is always one in great debate.
I'm mostly stock and N/A with a 4R70W auto so I went with 4.10s. Gas mileage went down a bit (I do about half highway) but I didn't buy my 'stang for gas mileage either. :)
It's all dependant on what you want to do with your car, so use these calculators to figure out what YOU want:
http://www.allfordmustangs.com/Detailed/641.shtml
http://www.allfordmustangs.com/Detailed/608.shtml
Wes
EDIT: Also, remember that in the quarter mile you won't be using overdrive (4th)... or if you are, you won't be using it for long!
EDIT 2: I got FRPP gears and also had the posi rebuilt and new axle bearings installed while the gears were being done.
It's also a great time to upgrade axles and differential if you plan on big HP or sticky tires.
