  • SN95 4.6L Mustang Tech
which is better & why?
  • Thread starter Thread starter usaf_branham
  • Start date Start date Apr 18, 2011
usaf_branham
927
134
84
Boston
Apr 18, 2011
  • Apr 18, 2011
when it comes to building an engine (for boost) which is better / makes more power...
39cc heads with a bigger dish piston
or
44cc heads with lesser dish piston
looking for compression ratio of around 8.8 to 1
or does it even matter?
trinity_gt
3,125
81
99
Canada
Apr 18, 2011
  • Apr 18, 2011
I'm going to go out on a limb a bit here and suggest the larger chamber and smaller piston dish would be a preferable choice.
My rationale would center on shrouding of the valves: Smaller chambers may move the chamber walls very close to the valve seats and may serve to limit flow, something with which the small-bore modular already has a problem.
usaf_branham
927
134
84
Boston
Apr 18, 2011
  • Apr 18, 2011
even with the twisted wedge heads?
bhuff30
6,037
35
129
Olathe KS
Apr 18, 2011
  • Apr 18, 2011
I actually don't know what the chambers between your 2 choices look like... but maximize the quench area. The quench is the area where the piston nearly kiss the face of the head at TDC. A larger and tighter quench area will make more power by making your engine less knock sensitive. When the piston approaches the head, all that volume of air between the head and the piston gets squeezed out and creates a lot of turbulence. This turbulence increases the speed of the burn, which makes a significant difference in the knock characteristics (much less likely to knock).
D
AOD TV cable replacement bushing - loose pin?
  • DuluthFoxbody
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:30 AM
DuluthFoxbody
D
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
