Which makes more power???????
Heads?? I wouldn't waste my time with a bigger cam unless you had bigger heads or at least ported and polished E7's. Do the cam and heads at the same time, you will crap your pants the first time you drive it. Then you will get used to it and want a supercharger.
I wouldn't expect much HP from either of those cams with your current combo. Even if your E7's were done as good as Power Heads, they are still the bottle neck. My suggestion is, keep the B cam in there until you can get some heads and then switch to an E cam or maybe a custom cam.
