Which motor mounts?
  • Thread starter Thread starter HaynStang
  • Start date Start date Feb 9, 2008
H
HaynStang
124
Portland
Feb 9, 2008
  • Feb 9, 2008
I need to replace my motor mounts and I'm not sure which ones to go with. Do the polyurethane mounts really deflect less or are they mainly just longer lasting? I'm trying to eliminate all of my drivetrain slop and make the car more responsive so I'll go with poly if they really do make a difference. It's a daily driver so soild mounts aren't an option. Opinions?
If poly is the way to go, which brand is best? I know Prothane mounts raise the engine up slightly so those are out. I see that UPR is selling their own mounts for $85, and that there are a ton of generic ones on ebay for around $75 that sellers are claiming to be identical to or better than Energy Suspension (http://cgi.ebay.com/ebaymotors/Ford...13QQitemZ230206981337QQrdZ1QQsspagenameZWD1V). Has anyone tried either of those?
H
HaynStang
124
Portland
Feb 14, 2008
  • Feb 14, 2008
Anyone?
BYRDPE
1,556
Memphis,Tn.
Feb 14, 2008
  • Feb 14, 2008
Subscribing...I'm about to replace mine. My last ones were vert mounts.
H
HaynStang
124
Portland
Feb 14, 2008
  • Feb 14, 2008
How long did your vert mounts hold up? Did they seem to hold the engine in place pretty firmly or do you think poly would do better?
M
mercurycapri
211
washington
Feb 14, 2008
  • Feb 14, 2008
I know you said no solid mounts but I had solid motor mounts I had little vibration and of course no flex. Just a thought
R
redneck15431
83
Feb 14, 2008
  • Feb 14, 2008
I would reccomend the poly mounts for a DD. I put those in my car last winter and it was worth it. Mine are prothane mounts and I know you said that you don't want those, but I have zero complaints about them. I had the stockers in there before and they were totally worn out. My engine would flop around like a wet noodle every time you would blip the throttle.
twistedwankel
200
Spring Hill, FL
Feb 15, 2008
  • Feb 15, 2008
I picked up a solid billet anchor from mustangsunlimited (I think) that quickly connected or disconnected from the block for racing purposes.
Best of both worlds. Solid when you want it and comfort when you are driving to work. If you have a multiple purpose car it's worth considering for a nominal cost.
I doubt I would ever use solid motor mounts for other than a purpose built car.
5.0 Nostalgia
904
CT
Feb 15, 2008
  • Feb 15, 2008
I have the Energy Suspension mounts and like them. Keep the motor in place without vibration.
earleys94gt
1,223
Ashley, Ohio
Feb 15, 2008
  • Feb 15, 2008
I just put the Energy Suspension mounts in mine, no vibrations either.
Polyurethane is definately the way to go for a street car.
fox-gt
204
TN
Feb 16, 2008
#10
  • Feb 16, 2008
  • #10
I went with Prothane because I wanted to raise the engine. I can definitely tell there is more vibration over the stock rubber ones, but I'm happy with them.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 17, 2008
#11
  • Feb 17, 2008
  • #11
Poly is the way to go. Much stronger and less movement of the engine. BTW it is also a good mount for your tranny. My gear shift used top bounce up and down now its solid.
ttop88
42
indiana
Feb 17, 2008
#12
  • Feb 17, 2008
  • #12
I changed everything on my car to poly. It made a noticeable difference.
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 4:28 AM
2v_johnny
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
