Which plugs?
nick_94cobra
25
hey everyone
I've got a 94 gt, 332 stroker, edelbrock peformer rpm heads, and i'm having a problem with spark knock on hard accel around 4-5k rpm. i've backed the timing back to 10* and i always run 93 octane. i am running stock motorcraft plugs. Any ideas on how to correct this problem? I've also cleaned the maf and installed new plug wires. the new wires are MSD 9mm.
Thanks for the help in advance
Those heads require Autolite 3924's...
What is your estimated static compression?
The compression will determine what gap you typically can run...
The 3924's can work in a pretty wide range of compression as well...
When i bought the stroker kit, with the 58cc heads, the compression was supposed to be 9.5:1. However, the pistons had .040" taken off them, so i'm figuring the compression to be around 10.3:1 or so
Either of those compressions are fine...many put it around .045-.050"...
But juiced, if you aren't having any spark blow-out (missing), .054" is fine...
I know many put it around .045-.050"...
Run as much gap as you can without it missing...
