Which rearend gear do you think???
its about 26 inches.
Ford AOD 4-spd automatic
2.40, 1.47, 1.00, 0.67
.67 OD at 60mph with a 26" tire is right about 2500 rpm with 6% figured in for converter slip.
28" tall would be about 2300 with 6% slip figured in. Could have more slip but still its close for most purposes.
For comparison, my 65 when it had a 3500 stall converter at 60mph with 3.89's turned right about 3200rpm. Thats with 6% slip figured which is pretty much dead on to what I saw. With my 4.56 gears now though, I see 3800 at 60.
TCI - TECHNICAL INFORMATION: Racing Calculators
If someone is using an AOD (or AODE/4R70W), most times they're using the lockup converter (I know I am), so there wouldn't be any slippage in OD.
In my 70, I'm using a 4R70W and with 3.00:1 gears and a 25.7" tire, I am turning 1920RPM at 70MPH in OD w/convert clutch engaged.
With 3.50 gears, that same combo would be turning 2240 RPM and with 3.70 gears it would be about 2370 or so.
Keep in mind--these are real world figures, and this is at 70, and I am using a tire that is slightly shorter than 26"
The 4R70W has slightly different gear ratios: 2.82 first, 1.55 second, 1.00 third and .70 OD, which means that with an AOD, you'd be turning a little bit less than what I am seeing, but really not worth mentioning.
