which rockers
  • Thread starter Thread starter myslo50
  • Start date Start date Sep 7, 2006
myslo50
247
ohio
Sep 7, 2006
  • Sep 7, 2006
i know by putting 1.7rr on a stock cam will increase the lift to 480, will the idle still stay the same or will it be a little choppy. will it be worth putting thoes rockers on my car will there be a noticeable difference.
is there any special mods i got to do if i buy the for install. like shims,longer pushrods,will the springs bind up, taller valve covers?
and who has them on a stock cam and if u like them?
myslo50
247
ohio
Sep 7, 2006
  • Sep 7, 2006
anyone?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 7, 2006
  • Sep 7, 2006
I've only heard...
I've heard that they add only 5hp or so
eagleautosports
139
Mebane NC
Sep 7, 2006
  • Sep 7, 2006
They won't change the idle quality because it doesn't increase the duration, only the net valve lift. It'll pick up only so much power because of the heads. If you're planning on more mods later on, you can go with them as long as any cam you get has the ratio on consideration.
afast93stang
1,407
North Texas
Sep 7, 2006
  • Sep 7, 2006
When I did my 1.7 Cobras it did have a slightly different sound to it. To the average person on the street it wont sound significantly different.
willys1
1,004
New Jersey
Sep 7, 2006
  • Sep 7, 2006
I have 1.7 RR's with Thumper heads and a stock cam. Idles the same just gives you more breathing up top! I wouldnt do it on stock heads though.
R
ratrapp2
121
  • Sep 8, 2006
i just put a set of 1.72s on my car with a b cam.my stock valve covers hit on the sides and i had to buy a set of fms valve covers to clear them.you might have to shim them if you have too much lifter preload but on my gt-40x heads they were fine.stock cobra rockers might clear because they are slighty more narrow than most aftermarket rockers.my cars sounds a little different but i felt alot more power because cam lift went from .480 to .515.i think it's worth the effort,especially if you have a stock cam.
T
Topdowncruise
207
Canada
Sep 9, 2006
  • Sep 9, 2006
I believe they do increase duration slightly so your idle may change a bit.
eagleautosports
139
Mebane NC
Sep 10, 2006
  • Sep 10, 2006
The rockers increase lift only, it doesn't add degrees. I've been to UTI and have studied valvetrain dynamics and the increase in power is fromt he additional lift.
8950HO
658
#10
  • Sep 10, 2006
  • #10
Crane Cams tech department said adding 1.7 rockers would provide the effect of adding an extra 1 or 2 degrees of duration to the cam on a stock 5.0L.
T
Topdowncruise
207
Canada
Sep 10, 2006
#11
  • Sep 10, 2006
  • #11
The Comp Cams guy told me the same thing when I got my cam.The guys from Crane and Comp Cams obviously don't study at UTI.
sawbones25
1,318
Virginia
Sep 10, 2006
#12
  • Sep 10, 2006
  • #12
There were no idle changes when I put 1.7's on some ported E7's.
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Sep 10, 2006
#13
  • Sep 10, 2006
  • #13
Wont the higher lift only come into play as the rpms go up? Im sure you wont notice a difference, and idle wont change. If you have aftermarket heads, cam, or valve springs, its a nice little mod to upgrade your engine, I wouldnt expect feeling a gain.
eagleautosports
139
Mebane NC
Sep 11, 2006
#14
  • Sep 11, 2006
  • #14
One to two degrees wouldn't make enough of a difference to have a real seat of the pants feel. I don't claim to know everything so it's cool guys. Besides, UTI wasn't all that great anyway so I wouldn't be surprised to have been misled by them. They only want your money and boy howdy did they get it.
352Ford2
393
Seattle,WA
Sep 11, 2006
#15
  • Sep 11, 2006
  • #15
http://www.compcams.com/Community/Articles/Details.asp?ID=153327675
read this
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
