Engine Which speed density cam to use?
I got to do some engine work and I'm trying to figure which cam is the best to use in my SD girl. I have both a Comp Cams 264HR and a Crower 15511; I'm using the stock DA1 computer and I'm looking for everyone's wise input to lean in the right direction.
This cam from Isky was specifically-made for speed-density cars. http://iskycams.com/shop/index.php?main_page=product_info&products_id=1150 There may be better options out there by now, but it was state of the art about 20-25 years ago. I can state from experience that it worked well in a California-smog-legal 302 with Y303 heads and a Cobra intake, I got to drive the car it was in and watch a dyno pull where it made 275rwhp through an AOD with full smog gear at World Ford Challenge 6 in 2003.
  • Useful
Reactions: General karthief
I like the specs on that cam; the Comp 264 is .512 and I'm worried about the piston to valve clearance and the 15511 on the list I'm not sure if it'll act right idling if the 87 I saw on YouTube is a indicator of drivability.
Provided you don’t have 300k miles on them, they will handle it
Ha,..check out the mod dudes answering opinion questions in the tech department. You guys should really just merge talk and tech together.
