which speedo gear should i use?
Falcon79
214
Dallas, TX
I am switching my 68 coupe 6 cylinder car over to a v8. I bought a c4 to go with my 302. Should i use the speedo gear that came with the new transmission? or should i use the one from the 6 cylinder transmission? I know very little about this so if someone can give me an iea what to do that would be great!
Thanks
If the speedometer was dead on before the engine swap, it'll be dead on afterwards. Almost all Ford transmissions used the same number of teeth on the drive gear in the transmission.....7 teeth. The only ones that didn't had rear gear ratios in the 3.90-4.30 range. If you changed the tire diameter, then that is the only thing that will throw off the speedo reading. Going to a shorter tire requires more teeth on the driven gear (one on the end of the cable) Taller tires, requires fewer teeth on this gear.
