Which subframes to get?
willys1 said:
2.34--60's ?,,,,,,what kind of slicks do you have?
:bang:
that is what happons when you dont heat them enough and you drop the clutch :bang:
They are Hoosier Quick Time Pro 26x9.5x15
This was my first time on slicks, so i didn't really konw what i was doing, i could't get them to smoke, so next month i am gona have a line lock and sub frames and smok'em in second...i hope :bang:
I recomend Maximum Motorsports Full Length Subframes. They are subframes not just connecters. They go from the firewall to the tq boxes and have other supports that go between the rear subframe and the tq boxes.
will i have a clearence problems with my wheels or anything? is it just a straight weld in?
No, you shouldn't. The subframes are thick steel which only hang down about half and inch, and the other reinforcemts tuck in the chassis, so no clearance problems there.
Use second gear...more revolutions of the tire...don't have to sit there as long...
My friend had slicks on and backed up into the "waterbox" and didn't burnem off enough through first gear and went a blistering 2.7 60 ft... :D
David
David
Its easier to stay in first,let them spin at 5 grand for 5-7 seconds!!
373's or steeper...second gear burnout best...for most combos of any sort
355's...first or second...
327's or lower...probably need to go first gear...
I know my friend that did that 2.7 60ft... :bang: ...went back and did a second gear nice rolling burnout and got a 1.8x 60ft...full weight, lowered gt but otherwise stock suspension... :shrug:
Do you do anything yourself? Or does your friend shake it for you too!!
Do you whine anymore or does someone else do it for you...oh wait I can answer that question...lol...you have to much stress in your life I can tell...you get all moody :rlaugh: :rlaugh: :rlaugh:
Its funny you talk like you've actually been down the drag strip.... :p
Willys you can get some help... :nice:
:owned:
To the original poster...check out MM's subframes :nice:
